Headlight switch replacement.
Old Jun 9, 2011 | 05:20 AM
Alex from GA's Avatar
Alex from GA
I bought a new switch a couple of years ago but forgot how to replace it. "I'm old and have CRS". The dash light resistor is bad. If it matters the truck is a '68 F250.
Old Jun 9, 2011 | 07:19 AM
tmcalavy's Avatar
tmcalavy
This requires some contortions...there is a little button/tab up on the body of the switch. You have to feel around and find this and hold it down while you pull the **** and shaft out of the switch housing. Then the switch bezel on the dash just unscrews and the switch drops out. Reverse the procedure to install, but beware...the replacement I got for my 69 F250 at Autozone was a direct, easy swap but it really grips the ****/shaft...seems like it won't release for another change...and I couldn't get the bezel back on with the replaement switch...the little ring that says Lights would not fit back on...and yeah, it's a cheap China replacement part, so no surprise there. It works, but must be a universal application.
Old Jun 10, 2011 | 01:33 PM
Alex from GA
Thank you.
Old Jan 23, 2015 | 10:07 PM
69issofine's Avatar
69issofine
when i first got my 69 f250 flatbed the battery kept going dead.found out the brake lights run through the headlight switch,replaced that and a lot of my lighting problems were solved. except for the buckets for the headlights the p.o. removed and lost the parts i had to go to the wrecking yard to get those parts.
Old Jan 23, 2015 | 11:04 PM
gangstakr's Avatar
gangstakr
Are you done with 2009? Now your on 2011
Dude when you get some sleep you might get into 2015 Go to bed!
Whitey Ford
Jun 15, 2015 09:20 AM
samjen
Jan 25, 2015 02:03 PM
narrowfarm
Oct 16, 2014 09:22 PM
Big-Red-Lariat
2009 - 2014 F150
Jun 22, 2014 02:05 PM
Truckee Bones
Jun 12, 2014 05:48 PM
