New Headliner questions
Old Jun 8, 2011 | 06:14 PM
pbevens's Avatar
pbevens
I am a newbie to this forum and am asking for some help with my 83 F150 XLT
I need to replace the headliner and don't know how to remove the interior trim pieces to get to the headliner. Do I need special tools or can I just use a screwdriver and big hammer??? The backing material seems to be in good condition but I just can't get it out and it appears that I need to remove the trim pieces to do that. Please advise.
Old Jun 8, 2011 | 06:31 PM
billt28's Avatar
billt28
Most of your trim pieces are screwed in. There are 3 pieces that are metal, (one over the windhsield, and the two over the doors) they have squeeze brackets behind them. Just pry them off. I think its the same for your '83 as it is for my '86.
Old Jun 8, 2011 | 06:36 PM
guindian28's Avatar
guindian28
the metal trim above the door and windshield and back glass are held in by metal spring clips, they will pull of with some effort. I start at at one end working my way to the taking care not to bend them, in other words, once the first clip frees, move down the peice, don't try to pull the entire piece from the one end. once the metal pieces are removed, you'll be able to access the screws holding the pillar trim in place. you'll also have to remove the dome light housing, just make sure you put all the screws back in, as they make up the circuit.
Old Jun 8, 2011 | 06:49 PM
pbevens's Avatar
pbevens
Thanks guys for your advice. Would it be better to pry at the top or the bottom of the piece. I am assuming that you just slip a screwdriver under the piece and pry it off ??
Old Jun 8, 2011 | 06:53 PM
billt28's Avatar
billt28
Correct. I pry from the bottom. A little more space there.
Anafiel
30
Feb 16, 2011 02:18 PM
LARIAT 85
Dec 11, 2010 05:12 PM
phubble
17
Mar 13, 2010 08:05 PM
2001gocougs
Feb 23, 2007 12:02 PM
MILLHOUSEB
May 7, 2004 01:27 AM
