Offroad & 4x4
My new trailer
Old Jun 7, 2011 | 08:57 AM
nobodyspecial's Avatar
nobodyspecial
My new trailer
I had been looking for a trailer that I could use for storage and moving. In my searches, I found one that can also be used for camping (its also set up for ice fishing). Its a 2005 6x12 Haulmark. It is slightly used, but in really good shape. It has been lined with spray insulation and then paneled over that. There has been more lights added, and a stereo that will run off either the vehicle or 12v battery in the trailer. It is also plumbed for a propane heater big enough to heat a garage. The guy said that they went a little overboard on the heater, and the the trailer is so well insulated that the pilot light is just about enough to heat it.
I am planning, in the future, to replace the tires with the same tires and wheels that I have on the Mountaineer, so in a worse case scenario, if I were to get two flats, my trailer spare is the same as the truck.
Sams club is no joke! (Stocking the camps snackery to the tune of roughly $950!)
Old Jun 8, 2011 | 05:50 PM
alpha/omega's Avatar
alpha/omega
I like it.
Its going to take an aweful lot of liquor to use up all that chaser. -too bad I know better.
Old Jun 9, 2011 | 02:57 AM
hav24wheel's Avatar
hav24wheel
That thing makes ur rig look tinny!!
Looks like it should be a good little trailer for you. I got myself a new trailer too, pick it up Friday, but it too will make my rig look small.
So to fit same size tires on the trailer, are you lifting it, or moving the fenders?
Old Jun 9, 2011 | 07:33 AM
alpha/omega
sawzall ;-)
Old Jun 9, 2011 | 08:02 AM
nobodyspecial
probably modify the fenders, I haven't even checked the bolt pattern on this axle, so I may need a new one.
Old Jun 9, 2011 | 08:06 AM
hav24wheel's Avatar
hav24wheel
Most likely its a 5 on 4.5
Old Jun 9, 2011 | 11:18 AM
alpha/omega
All the trailers I own are 5x4.5" which should be the same as an explorer/mountaineer. - well, thats what my ranger was.
Old Jun 9, 2011 | 01:10 PM
nobodyspecial
I knew a lot of trailers are 5x4.5, I just didn't want to say it was without checking.
nobodyspecial
Offroad & 4x4
28
Aug 9, 2011 03:12 PM
nobodyspecial
16
Jul 24, 2011 09:05 AM
nobodyspecial
Oct 4, 2010 10:23 PM
nobodyspecial
Offroad & 4x4
Feb 8, 2010 06:03 PM
nobodyspecial
30
May 20, 2009 04:40 PM
