Help 1st time buyer
Old Jun 6, 2011 | 11:51 AM
newguy72's Avatar
newguy72
Help 1st time buyer
Alright hello all ford truck enthuasists. I am going to say first i am relativley new at this and sorry if i ask a repeated question and/or a possible stupid one. I have been researching diesel engines for the past three months, so i know the basics and starting to get the lingo, so dumb-down answers would be apperciated, however i am smart enough to look any tech terms up. Here we go, i am buying my first car/truck and i want to get a 7.3l diesel 94-97 ford f250. I am looking for advice on want some possible red flags are. Also, i was wondering how many miles can the fuel pump usauly go before needing maintance and or replacing, and at what cost. Lastly, i under stand the some 97s do not have a block heater, and was wondering how much it would cost to get one installed. Any advice is apperciated. Thank You.
Old Jun 6, 2011 | 12:28 PM
97XLT4X4's Avatar
97XLT4X4
hello and welcome!!!
read through this section of buying a power-stoke here.....it has the basics pretty well....
http://pages.prodigy.net/stevebaz/_i...az/index3.html
other than that, my truck has 267k on it and i have no record of a fuel pump replacement....stock for stock the manual is a little better for longevity....any more specific questions, ask away!
Old Jun 6, 2011 | 07:51 PM
fordpride's Avatar
fordpride
Here ya go
Things To Look For When Buying A Used Power Stroke Diesel
Turbo:
You might take the air tube off the back of the air filter and look inside of it. If there is dirt build up, that is a very bad sign, so are the turbo fins looking sand blasted or bent. A little oily film is normal since the valve cover breather exits inside the tube.
Airbox:
Check the two bolts holding down the airbox lid. If they are plastic with a square recess, it is a recalled part. The recall is expired, but without the updated lid the risk of dirt infiltration is greater, the lid was updated with more supports and the updated bolts are metal with a straight slot. If it is the old style, you spend around $80 to update it.
Tranny:
If you buy a truck with an auto tranny, finding out if it's been maintained is essential, as the E4OD is an expensive transmission. Also, (if auto) seeing if the truck has an auxiliary transmission cooler would be worthwhile. For sticks, listen for clunking when shutting off or small vibration while operating. It could be an indication of a dual mass flywheel going out. Many have replaced them with single mass units.
Rear Gear Ratio:
4:10 will pull better, get slightly lower mpg’s and run a higher RPM compared to 3:55.
Coolant:
Ask the previous owner about the coolant - have they been adding FW16 or DCA4 to keep a proper SCA level? It is very important for stopping cavitation. You can get test strips to check the SCA level from NAPA, International, or Ford. I would test the current condition while looking over the truck, the SCA level should be between 1.5 and 3.0. Also, see if it has a block heater (it was an option on 97's).
Front end:
Check the front end for wear, or have an alignment shop check out the ball joints and steering linkage (tie rod ends). If they are shot, it is spendy (all four tie rods are around $400 just for parts, ball joint labor is also very spendy)
Oil:
The questions to ask are how often the oil was changed (at least every 5,000) and what kind of oil they used (diesel rated)? An oil analysis could tell you if there might be an engine problem or not.
Aftermarket stuff:
Seeing if the truck has got an aftermarket downpipe would be nice, a chip, or gauges (pyrometer, trans temp, etc.). Ask about any added items and who installed them.
Glow Plugs/Relay:
Find out if the glow plugs are in good working condition as well as the relay. Ask if either has been changed and when. You can check the glow plug resistance through the valve cover connector if needed (http://forums.ford-diesel.com/cgi-bi...&f=21&t=005210), and the relay should have power to both large terminals on top when the key is turned on, and one of the terminals should go out before ~2 minutes.
Injector o-rings:
The injector O-rings have been known to be a problem. The new o-ring sets have a pink middle seal. If the truck has an o-ring problem, one of the signs can be a discoloration of the fuel in the filter bowl. There is a drain on the passenger side front of the filter bowl for draining water (the filter is also the water separator) and you can catch some of the drained fuel in a jar – it should be dingy yellow and not blue or dark.
Leaks and Drips:
You can check the valley between the heads of the V8 for moisture and/or fluid. It should be dry not wet. Most leaks will run through this valley and down the back of the motor dripping off by the tranny/engine coupling.
VIN number:
If you take the VIN to any dealer, they can tell you when it was built, when it went into service, and some of the work that might have been done on it. You can also run prospective VIN's through Carfax.com to see the title history.
SIXTFOR
May 23, 2014 04:06 PM
NightRacer
38
Jun 6, 2013 12:47 PM
Ford Agian
2004 - 2008 F150
Dec 7, 2011 05:02 AM
Want_a_7.3diesel
Oct 7, 2009 09:17 PM
fmco_muddin
Iowa Chapter
Feb 5, 2008 08:46 PM
