Vac pump failure
Old Jun 6, 2011 | 11:06 AM
superduty4x4's Avatar
superduty4x4
Vac pump failure
Pretty sure mine is dying a slow death- power brakes aren't working so hot and the AC blows out the defrost vents until RPM's come up. The pump is also making more noise and there is a buzzing under the dash that goes up/down with rpm.
Question- will a failing vac pump cause the e-brake light in the dash to come on? Since this problem started the e-brake light has been on also. At first it was intermittent, now it's on all the time.
Old Jun 6, 2011 | 11:17 AM
Talyn's Avatar
Talyn
Yes, the brake light on the dash is actually an emergency light.
But also turns on with the parking break to warn you its on.
Its not hard to change.
Old Jun 6, 2011 | 11:22 AM
superduty4x4
I figured so but wanted to confirm.
Maybe on your truck, not on mine.
Old Jun 6, 2011 | 12:12 PM
Talyn's Avatar
Talyn
There is a wire that connects to the pedal assembly down there, its probably un-plugged.
Old Jun 6, 2011 | 12:27 PM
superduty4x4
I'm well aware of how it's setup from the factory but thanks anyway.
Old Jun 6, 2011 | 12:39 PM
Talyn's Avatar
Talyn
Well fix it then smartass. :P
Old Jun 6, 2011 | 12:46 PM
superduty4x4
I don't need to fix it, there's a reason the wire isn't plugged into the cheesy little sensor on the e-brake.
Old Jun 6, 2011 | 01:23 PM
Talyn's Avatar
Talyn
Care to share?
Old Jun 6, 2011 | 01:33 PM
superduty4x4
I wired it to a switch for my AIC since the stock sensor is so temperamental. The AIC needs to see the light on or it won't activate, and way back when I first installed it in my SD the switch on the e-brake wasn't working right. Run the e-brake wire to a toggle switch, flip the switch, light comes on and life is good.
Since the e-brake actually gets used on a regular basis and the sensor is working (at least for now) in my new truck I didn't need the switch, but I already had it setup so I used it anyway.
Old Jun 6, 2011 | 03:05 PM
Talyn's Avatar
Talyn
oh, that makes sense. cool.
Old Jun 6, 2011 | 03:43 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Been through 2 vacuum pumps on my truck.. On both occasions, no lights came on in the dash. Not to say they aren't supposed to, but mine didn't. The e-brake light does work right on my truck too.. Vacuum pump is a 30 minute swap though.
Old Jun 6, 2011 | 04:04 PM
superduty4x4
I'll probably pull the pump off Whitey tonight and put it on the new truck, hopefully it solves the problem.
Old Jun 6, 2011 | 04:09 PM
YoungFordAddict66's Avatar
YoungFordAddict66
Yea better fix it tonight while your ar home. You would hate to get stranded away from home with no brakes like i did, 20 miles from home and some sketchy brakes is the least fun i have had in my truck.
Old Jun 6, 2011 | 04:49 PM
superduty4x4
I've been driving it all weekend with essentially no power brakes, I'm not too worried about it you just need to be aware of it so you don't slam into someone.
Old Jun 6, 2011 | 04:50 PM
strokin'_tatsch
Having a 5 speed helps a little too. I don't like downshifting stock autos.. It doesn't feel right when you do.. At least none of the stock E4ODs or 4R100's I've driven felt good manually downshifting. lol
