The worse problem(s) on a 300 inline 6
May 18, 2022 | 11:53 AM
Quote:
Originally Posted by
p-nut
I had a '94 4x4 with the 4.9 and here's the problems I had.
1. Distributor gear roll pin backed out and dropped the gear destroying the camshaft. Gave me reason to swap in comp cams bump stick.
2. Air injection manifold cracked at each cylinder, replaced manifold just to find the air pump didn't work so I deleted the whole system.
3. Could never get the timing to set correctly, even with the "plug" pulled it would always try to advance.
4. Endless EGR position sensor codes probably the fault of the new parts being outo f ohm range from the factory.
5. Rocker arms wearing through.
6. Intake leaks (many).
This was all after about 340k miles on the clock so I wasn't angry about it. Truck still runs and last I head it was over 400k.
Do you remember what the thread pitch is for the tubes going into the head at each cylinder?
May 30, 2022 | 05:57 PM
Spout removal
My 1995 f150 4.9 efi won't start with the spout removed but does with it in timing marks line up at 10deg before 0 runs good at idle but has no power do I need to remove the spout and retime it
ftrk66
31
Jan 6, 2012 06:18 AM
Denver
May 19, 2011 06:47 PM
Chas1234
Jan 7, 2003 06:41 PM
corny
Apr 21, 2001 11:38 AM
rogwelch
Feb 12, 2000 11:29 PM
1979 ,
1985 ,
300 ,
ac ,
air ,
bleeder ,
cyl ,
f100 ,
f150 ,
ford ,
inline ,
problems ,
sale ,
troubleshooting ,
truck
