Modular V10 (6.8l)
My engine is toast...
Old Jun 17, 2011 | 05:30 PM
  #31
Old93junk's Avatar
Old93junk
Ever consider another possibility?
Have a vindictive X-wife or a enemy?
More than 1 engine has been ruined by the midnight raid that drains 4 qts or more into a bucket, then puts the plug back in, and drives off to wait, watch and snicker about their evil deed.
Old Jun 17, 2011 | 05:33 PM
  #32
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by DawgYa
Well, what have read says your 99 triton v10 was factory rated at 305hp and 420lb·ft,
You didn't read that here.
The numbers you are quoting are for the 2-valve PI-head V10 in the E-series vans from 2000 and up.
Old Jun 17, 2011 | 05:43 PM
  #33
DawgYa's Avatar
DawgYa
Originally Posted by WyoCobra
I've been racing (SCCA, NMRA, NHRA, etc.) Mustangs for about the same length of time. You do realize that there have been a lot of different engines in Mustangs, right? My '03 Cobra once made 21 more RWHP with nothing more than a CAI. That is a supercharged engine, but I never specified exactly which engines I was talking about. LS1 Camaros EASILY make 30+ more HP with headers and exhaust. Don't take my word for it, though; ask people who own them. I guess Gale Banks is full of it, too.
Yes I am very familiar with the 03-04 32 valve "terminator" motors.
And not that Gale Banks "is full of it, too" but real world results vary tremendously from the controlled testing parts developers do.
  #34
WyoCobra's Avatar
WyoCobra
Originally Posted by mwsF250
Been there, done that.
You WILL notice a difference with PI. The 275/410 figures are correct for NPI.
And I wholeheartedly recommend Mike's tunes. I can't see how the stock '99 tune could be anything but worse on a PI engine.
Other tips:
Don't pull the cab - no need. Pull the fan and radiator and front bulkhead so you can stand between engine and bumper and you can get to everything quite easily.
I just used my original '99 fuel rails (with new o-rings) and wiring harnesses so I didn't have to bother disconnecting anything. Worked dandy! I recall the PI intake used two less (or more?) bolts to anchor the fuel rail, but I just used what lined up and it worked fine.
The PI intake should have an EGR block off plate which you can remove and install your EGR (if you were lucky enough to have one).
You will need to modify one heater hose. On the '99, one hose is 5/8" and goes between firewall and back of intake manifold. The PI intake has a 3/4" bung on the front. A foot of 5/8 hose and a foot of 3/4 hose coupled together with a reducer solves that....
Thank you!
I certainly plan on getting a tune from 5-star. They seem well respected around here and seem to know their stuff from the threads I've read.
The engine I bought is complete minus the wiring harness and accessories. Can I use the PI rails and injectors? Is the engine harness different on the newer engines or something?
I have EGR but don't plan on re-installing it. It wasn't functioning properly (it was throwing an "insufficient flow" code on a regular basis) and I don't really want to spend a bunch of money repairing it.
I think I will probably just pull the motor out of the front like Cooper24 did. My Mustang is currently tying up my lift, anyway.
Thanks again!
Old Jun 17, 2011 | 06:59 PM
  #35
mwsF250's Avatar
mwsF250
I did not look close enough at things to know if the PI fuel rail would have connected up.... The intake I had came from a junkya.... err, recycler and they had slashed the fuel lines and bent the rail during removal. So I just went with my '99 injectors (actually, brand new replacements) and rail.
If the EGR was not working, then probably not worth fussing with. Probably less than 1 mpg penalty to give it up.
Tell Mike if you are going to leave off the EGR. I believe he can modify software to prevent CEL with no EGR.
Old Feb 26, 2012 | 07:07 PM
  #36
SDV10's Avatar
SDV10
So, I need to make sure that I understand all of this. The PI heads motor will work in the 99 without altering the PCM. I got a PI motor for free and just sent it off to machine shop to fix the burnt valves and clean the block. I do not want to spend all this money to then tell the wife 'oh, by the way I need a tune.' Well, i do want that but not that way. I do have an egr and it is working fine but the motor is not and I am fed up with good money after bad. Hence the newer motor going to machine shop. I do know that the injectors are different but mine (i think) are fine.
mhaskell
Modular V10 (6.8l)
Oct 1, 2016 07:30 PM
Robertf2
Jun 26, 2014 10:18 PM
chloichina
1997 - 2003 F150
Jun 26, 2013 03:28 PM
1998Nascar
Modular V8 (4.6L, 5.4L)
Jan 19, 2012 10:01 AM
Silver2011
16
May 19, 2011 06:54 AM
