Charging issues ?????????
Old Jun 5, 2011 | 04:37 PM
smithf250's Avatar
smithf250
Ok here we go again I just put new batteries, altenator, regulator, starter, and starter selenoid on my truck!! The problem is when its idling the regulator test bed but as soon as you run the rpms up to 1000 everything shows good. Any ideas on what the problem might be?
Old Jun 5, 2011 | 04:46 PM
joe f350's Avatar
joe f350
mine dose the same thing i hae never found a proplem with that inless u do a lot of idel time
Old Jun 5, 2011 | 04:49 PM
smithf250's Avatar
smithf250
i have been here lately cause i work out of town two weeks at a time so i see alot of idle time on the phone and what not
Old Jun 5, 2011 | 04:50 PM
smithf250's Avatar
smithf250
how do you add a profile pic
Old Jun 5, 2011 | 07:25 PM
Militaryman4455's Avatar
Militaryman4455
Just click the User CP button on the top left of the page and click edit avatar in that menu...
Old Jun 6, 2011 | 11:59 AM
Diesel Fiend's Avatar
Diesel Fiend
Check that the ground connections are all good around the regulator. I had the same problem and found that if the ground connections were corroded or loose, it would take higher RPMs to get any charge. Not just the battery connections, but the small connections around the regulator.
Old Jun 6, 2011 | 01:27 PM
wreckinball's Avatar
wreckinball
Belts, often overlooked, didnt see them on your replacement list. If not snugged or if worn out, they can cause what you said because they dont make solid contact until they spin faster or warm up
Edit, when this happens do the headlights dim? If not there may be a gauge issue.
fordtough81
Aug 1, 2015 10:55 PM
Matt5324
Oct 28, 2014 12:39 PM
steve benson
Apr 17, 2006 09:57 PM
yolbolsom
Mar 10, 2003 07:27 PM
AaronW
Sep 11, 2001 02:37 AM
