hey guys, 04 psd 5sp trq sft. My tranny keeps given me erratic shifts,sometimes drops out of od into dr, other times ill come to a stop and go to take off it won't go back into 1st.Ihave to put it into n then back into d to get it to go. Fluid and filter change bout 1000 miles ago,with SP fluid. Temp run at 205, any help would be great.
Were you having this problem before the fluid change? Are you positive SP was used? My tranny doesn't get that hot pulling a 13K fifth wheel across the desert in August. I'm assuming that 205 was the tranny temp?
No this just started doing this about 2 wks ago. SP fluid was used. Yes 205 is tranny temp,had my computer plugged in with auto enginuity on it,not to familiar with how to use it or what parameters should be.
Are you running a tuner of any sort? Now or in the past? I would think a bad tft but the erratic shifting plus high temp. says major problem. Maybe Mark K. will come along and comment. He's the resident tranny engineer.
