EGR Blocked Off?
Old 06-05-2011, 12:04 PM
Roasted7's Avatar
Roasted7
Roasted7 is offline
EGR Blocked Off?
Is there an easy way to tell if the egr has been blocked off by a previous owner?
Old 06-05-2011, 12:19 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
if they installed a deleate kit you could tell
but if they just weld plugs on both ends of the egr cooler you wont know till you take it apart
and some did the sneaky up pipe welded inside I believe
you could pull the egr valve and see if its dirty or clean
Old 06-05-2011, 12:39 PM
Roasted7's Avatar
Roasted7
Roasted7 is offline
I'm looking down in there with a flash light and I don't see a cooler. I just see a stainless steel pipe, about 3/4" dia., that runs from the back of the oil cooler, bends around in a "u" runs down the length where I'd expect to see a egr cooler and then up into the intake manifold.
Delete kit? The egr valve is in the manifold and plugged in. I guess it should be clean if delete kit installed?
Old 06-05-2011, 12:44 PM
BLADE35's Avatar
BLADE35
if the cooler gone then
sounds like a sinister deleate does the 3/4pipe go into a blue fittting at the intake manafold
Old 06-05-2011, 12:47 PM
olfordsnstone's Avatar
olfordsnstone
olfordsnstone is offline
Unless the delete was done after the egr got cruddy. Then it might still be cruddy, if they didn't clean it.
Old 06-05-2011, 12:50 PM
Roasted7's Avatar
Roasted7
Roasted7 is offline
I see a short blue hose off the oil cooler to the stainless pipe, but the pipe looks like it butts to the manifold with a flange.
Old 06-05-2011, 12:58 PM
BLADE35's Avatar
BLADE35
its deleated
if the flange is blue then its a sinister
blue hose is the newer hose
Old 06-05-2011, 01:47 PM
cheezit's Avatar
cheezit
cheezit is offline
with the truck together and running active command egr and moniter iat2. with egr flowing iat will climb if the egr system is in tact
Old 06-05-2011, 02:58 PM
Roasted7's Avatar
Roasted7
Roasted7 is offline
I'll give that a try. It's hard to see the up pipe as it's hiden behind the 4" exhaust off the back of the turbo among other things. I tried to look from under the truck as well but heat shields are in the way.
Without any doubt, the cooler is definately gone which should mean the up (Y) pipe had to be replaced or at least plugged off.
I'm still learning what all the previous owner has done to this truck. Dealer told me that ARP studs were installed but that was all he knew. I can tell the engine has been pulled at least once. I just found out last month that I have a remote starter and alarm system but I don't have the remote.
Old 06-05-2011, 03:00 PM
cheezit's Avatar
cheezit
cheezit is offline
look at the remote start module and see who made it. call the company and tell you need a remote. they will sell you one.
Old 06-05-2011, 03:17 PM
BLADE35's Avatar
BLADE35
i bought a truck that had a ungo box alarm they sent me a new remote for it you will need serial numbers and model numbers i had to order from a ungo box dealer
if the egr cooler is gone they had to replace the up pipe sounds like a sinister egr deleate
i also found on that truck had a lug that needed a key on each tire I pressed a foam cup into it got the pattern and they sent me a lug key
might want to check your lugs before you get stranded
Old 06-05-2011, 04:24 PM
Roasted7's Avatar
Roasted7
Roasted7 is offline
I found a local mechanic here that had a couple keys that fit. He just gave me both of them no charge.
Old 06-05-2011, 09:25 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
Smart! (I woulda tried a chisel and 3 pound hammer or something like that)
