1978 - 1996 Big Bronco
The Trifecta !
Old Mar 25, 2003 | 06:08 PM
Dutch123's Avatar
Dutch123
Smile The Trifecta !
In the past month: window motor, oil pan gasket, alternator. Anyone have a similar "3 peat" or trifecta. So, what's next.
1996 XLT 133,750 miles
Dutch
Old Mar 25, 2003 | 06:27 PM
mrwizard's Avatar
mrwizard
The Trifecta !
Clogged fuel injectors, bad MAP sensor, intake manifold gasket leak.
Old Mar 25, 2003 | 06:55 PM
christop43's Avatar
christop43
The Trifecta !
Starter, water pump, U-joint
Old Mar 26, 2003 | 08:11 AM
Tommyquest's Avatar
Tommyquest
The Trifecta !
starter, bad injector, header gasket
Old Mar 26, 2003 | 10:16 AM
jake_i_am's Avatar
jake_i_am
The Trifecta !
This is like EVERY month for me!!!!!
This month: Carb, P/S Pump, Ignition Switch
Previous Month: Alternator, Ignition Module, Coil
Should I keep going?
I still got the love, though.....
Old Mar 26, 2003 | 11:55 AM
tim330i's Avatar
tim330i
The Trifecta !
Leaking PS pump, oil pan, transmission!
Broken rear window motor, driver door lock motor, passenger door lock motor
I have the tail gate, doors apart to fix those problems. Have the parts for the oil pan and tranny, need to find the PS problem still.
Tim
Old Mar 26, 2003 | 07:14 PM
greystreak92's Avatar
greystreak92
The Trifecta !
Gee, you guys are lucky...only three problems a month? WOW!
Old Mar 26, 2003 | 08:11 PM
tite4x4's Avatar
tite4x4
The Trifecta !
You ALL have had it made. Especially if you only had to replace 1 or 2 parts, or even 3, at once.
In my case the tranny went belly up in November of 2001 and had it rebuilt. A month later(December 2001) the engine blew a hole in #5 piston. So I had it rebuilt and I ended up having to wait 10 months for all the parts(mostly performance parts) in order to get it running in better than new condition. Well no sooner than 2 or 3 weeks after engine was running and I was driving it around town and the transfer case had broke off, in November/December 2003, because the trannies output shaft had seized. rebuilt tranny again and also rebuilt transfer case.
Well, just last month I was driving off-road all day long with no problems. Until I was on my way home on the highway, the engine just dies. after scratching my head for 5 minutes trying to figure out whyI was able to start it and dirve off. About 40 miles later the engine dies again, and that time I had to be towed home. Come to find out that the fuel pump(so I thought) went bad, and the ignition module was definately bad. The poor thing was still not running right, so I started to pull codes. Within a matter of 2 weeks, last month, I had replaced the
1) fuel pump, Fuel filter, & Fuel pressure regulator
2) Ignition module
3) Distributer
4) MAP Sensor
5) Alternator
6) O2 Sensor
So that's about 8 parts I had to replace. And now my Starter was on its way out so I just replaced last week. It almost seems as though that my rig is jinksed. What's next???
Good luck to all
Old Mar 27, 2003 | 07:07 AM
fcarruth's Avatar
fcarruth
The Trifecta !
Water Pump, Smog Pump and Timing Chain.
Old Mar 27, 2003 | 08:36 PM
broncoholic's Avatar
broncoholic
The Trifecta !
carbureator (rebuilt), water pump, push rods (intake only)
Old Mar 29, 2003 | 01:54 AM
tite4x4's Avatar
tite4x4
The Trifecta !
I forgot one other part that I replaced in my last post. Which was the water pump, that I had replaced along with all the other stuff.
The starter motor that I put in last week, had a slight hickup though. The gear of starter was hitting the fly wheel while engine was running. So I had contacted PowerMaster, the maker of my new Starter and the 200amp alternator that I installed last month. Well needless to say that they had the solution and then next day FedEx a set of shims for this very problem, and I was up and running almost the next day. Now that was customer service and why I am pretty much a loyal customer of PowerMaster.
Old Mar 31, 2003 | 06:06 PM
Hwy Apostle's Avatar
Hwy Apostle
The Trifecta !
This month has been a bad one for me and my bronco.
1st engine blew
2nd tranny modulator pump went out after new engine was put in
3rd & hopefully last my radiator blew today on the pass side in the plastic cant fix must replace am in the process of doing that now.
total wallet setback rite at $4,000.00
Old Mar 31, 2003 | 08:12 PM
tite4x4's Avatar
tite4x4
The Trifecta !
Hey Hwy Apostle
You got off easy with only $4000. I think in the past two or three years I had probably spent about $15,000 roughly. I'm afraid to total the amount spent. It's scarry. Could have bought a new rig with this money. But I wouldn't have had all the goodies put on, that I have now.
Old Mar 31, 2003 | 09:10 PM
treehugger36's Avatar
treehugger36
The Trifecta !
geesh, you guys are depressing me! I come back from spring break and 10days without my FTE and I check the forum and this is what I see?! Come on guys! where is the Love?!
Atleast you guys could find all the parts you want! I still cant find that freaking Turn Signal Fluid Pump! Geesh! I found the site with the fluid, but NO PUMP!
HA HA HA
Old Mar 31, 2003 | 10:13 PM
greystreak92
The Trifecta !
Hey Treehugger,
Did that site have muffler bearing races too. Havin' one heck of a time finding a set for mine.
