93' 5.0 timing help
Old Jun 4, 2011 | 08:35 PM
Deven Mays's Avatar
Deven Mays
Trailering
93' 5.0 timing help
My main question is what do you unplug before at distributor before checking timing. There's only one plug at the distributer that has half a dozen wires that disables the ignition. How do you bypass the advance on this model?
Old Jun 4, 2011 | 09:38 PM
timbersteel's Avatar
timbersteel
Spout connector located on driver side, near TFI/ICM module. I don't have a picture for you, but I know there is one floating around here courtesy of SubFord. Very easy to locate. If yours has never been touched then it may be wrapped in electrical or tacky cloth.
It should be Grey in color.
Old Jun 4, 2011 | 11:53 PM
ford2go's Avatar
ford2go
SPOUT plugs have been done a few ways. Main thing to know is that it's a one pin plug. One of the lines from the TFI connects to the SPOUT.
When I had an F150, it was a single pin connector that pulled apart. I have heard of some that had a jumper that you pulled out to disconnect the wire.
fordfuelinjection.com may have some pictures.
hj
Old Jun 5, 2011 | 07:50 AM
subford's Avatar
subford
It sould be as in the photo below:
Old Jun 5, 2011 | 11:27 AM
Deven Mays's Avatar
Deven Mays
Trailering
Bingo ! Found it !
Thanks guys. the pic Subford supplied is just like mine. Well, my wife's. We just got the truck for her. Pictures to come. Anyway thanks again. With all the vehicles and work I've done over the years I had never even heard of a spout connector or shorting bar !
ampslw
18
Mar 11, 2010 08:02 PM
daves54
13
Feb 16, 2009 04:17 PM
wildstang
17
Jan 27, 2006 09:03 PM
fordeverpower
Dec 5, 2003 08:13 PM
68torino
Nov 3, 2003 03:01 PM
