I get lifetime free nitrogen fill-ups where I got my tires, so if I have to use some "top off" air while on the road, they will purge and refill at no charge when I get back home.
As for making a difference, I haven't lost more than 2 psi in two of my tires in a year's time, and they retained their pressure perfectly through the winter. As for the other two tires, they were not purged well when they were first installed and lost some pressure, but once I discovered that and had them re-purged and refilled with nitrogen, it's now been nearly 9 months with no drop in pressure.
Observations... the tires which lost pressure show abnormal wear, but the two which never lost air still show excellent tread depth after 20,000 miles. At the rate they are wearing, I should get another 30K-40K miles off of them. (Michelin LTX AT2's, 285's on stock rims)
I know of one company (at least 20 big rigs ) who studied this issue extensively and has switched every tire on every truck over to nitrogen and is seeing the savings in tire life.
Nitrogen molecules are larger than air molecules, so they are less likely to leak. Nitrogen is also dryer. That means little to no moisture in the tire which makes a difference with TPMS vehicles. You will not see any noticeable mileage increases or decreases with either one.
Does anyone think it would be cost effective when you factor in better tire life?
IMHO...if you are regularly checking your tire pressure.... (like checking fluids/oil, etc) not really. Many won't take the time to go over their vehicles and check out the basics, but IF you do, (Like we all should) no, it shouldn't make any difference.
But, if youre a "fill and forget" kinda guy.... yeah, probably.
I don't understand how it improves fuel economy or tire life. Please explain this to me.
If your tires are properly inflated, you will get optimal MPG's.
Likewise, overinflated, you get excessive wear in the middle and poor grip, and under inflated you get wear on the outsides and very poor preformance/mileage.
Ummmm. Mark was being sarcastic. He owns and operates an auto service center.
Its a law here in California that all tire stores must use Nitrogen in there new tires I was told. After that Ford, Firestone thing @ blames the other.
