Blower motor problem HELP!
Old Jun 4, 2011 | 01:43 PM
chad85's Avatar
chad85
Ok my blower motor is not switching speeds, it is just blowing low, when you move the switch to high the speed doesnt change. I replaced the switch, and it did not fix the problem. What else could it be? In this Texas heat it is REALLY frustrating
Old Jun 4, 2011 | 01:49 PM
Boba Fett's Avatar
Boba Fett
It's usually never the switch.... There is a resistor mounted on the heater box that controls the speeds..... Trace the wires and you should find it..... Order up a new one and you should be in business!
Old Jun 4, 2011 | 02:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If the truck has Hi/Lo vents or factory A/C, the blower motor resistor is different than with a heater only.
E3TZ-18591-A (replaced C9AZ-18591-A) .. Blower Resistor-Use with Heater / Available from Ford.
MSRP: $29.63 // FTE sponsor PARTSGUYED.COM price: $21.34.
Applications: 1973/86 F100/350 / 1975/86 Econoline / 1978/86 Bronco // 1969/78 Galaxie/LTD/Mercury Marquis.
D3TZ-19706-A.. Blower Motor Resister-Use with factory installed Integral A/C or Hi/Lo vents / Obsolete
Applications: 1973/79 F100/350 / 1978/79 Bronco.
13 available NOS from FoMoCo Dealers, obsolete parts vendors.
Old Jun 4, 2011 | 02:43 PM
chad85's Avatar
chad85
Oh, and yes my truck does have factory A/C
Old Jun 4, 2011 | 05:25 PM
chad85's Avatar
chad85
Ah, never mind it was actually a loose connection at the switch. Glad to have my A/C back!
mark89
Oct 4, 2015 11:23 AM
03F250SD
Apr 26, 2015 12:42 PM
wjb21ndtown
2004 - 2008 F150
Apr 25, 2014 03:19 PM
sailorjohn
Dec 30, 2013 06:13 AM
sailorjohn
Dec 29, 2013 11:51 AM
