Engine Stall????
Old Jun 3, 2011 | 11:58 PM
neumayr83's Avatar
neumayr83
Engine Stall????
The other day i was getting my 1999 F-350 XLT 7.3L smogged... if failed the first test, (i knew it was something to do with the glow plugs) so i knew what i had to do... i ended up having to replace the glow plug relay... but what questioned me was that everytime they plugged in the truck for the smog test... it stalled the engine.. they did it like 4 or 5 times and it always stalled the engine... its an auto transmission too
Any ideas of what could be wrong??
Old Jun 4, 2011 | 06:25 AM
hanklin's Avatar
hanklin
Run from that shop as fast as you can. I just had mine done (in Cal) and its a visual test, no hookup. Maybe the dumba$$es were hooking up for a gasser. Pretty sure I am correct. As long as you dont blow a ton of smoke and the ses light is not on then you are o.k. If you took off the cat then you have to replace it. Some are exempt like mine
good luck
p.s mine cost $58.00
Old Jun 4, 2011 | 07:45 AM
senix's Avatar
senix
Glow plugs would have nothing to do with failing a smog test anyway. Hankin is right, don't go there.
Old Jun 4, 2011 | 04:41 PM
neumayr83's Avatar
neumayr83
Okay thanks!
Old Jun 4, 2011 | 04:47 PM
ToMang07's Avatar
ToMang07
good luck
Generally, the Manual Trucks had a Cat/Muffler combo, and the Auto's had just the Muffler.
I think the only difference in the CA trucks is they have a different (special) Glow Plug relay.... Don't see how that would effect emissions, tho.
Agreed.
Old Jun 4, 2011 | 07:33 PM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old Jun 4, 2011 | 07:38 PM
ToMang07's Avatar
ToMang07
Haha, love the ZG avatar!
OP: One other thing, did it only stall when hooke dto the OBDII port, or when driving/idleing, too?
Old Jun 4, 2011 | 09:56 PM
F350-6's Avatar
F350-6
We've read about this before. There's something with that machine that will cause your truck to stall if they plug it in. Plugging the truck in is not required for the test on a diesel. If you search the 7.3 section here, I'm sure you'll find the threads that tell you why plugging it in is not required and read about others whose truck stalled when it was plugged in.
Old Jun 6, 2011 | 09:37 AM
neumayr83's Avatar
neumayr83
It only stalled when hooked up to the OBDII port, its never stalled or done anything strange when just driving
jbrandall89
37
Oct 17, 2011 09:25 PM
stangclassic66
Aug 2, 2011 12:06 PM
Bull1717
2004 - 2008 F150
Apr 24, 2011 11:26 PM
lazerf250
Mar 21, 2007 07:05 PM
moocanfly
4 Cylinder Engines
Sep 15, 2004 10:28 PM
