Took a load of scrap on a trailer and in the bed to the metal recycler about 5 years ago. My receipt showed 13,080lbs when I went across the scales. That was truck, trailer, and load. This was my '83 F-250 Reg Cab, 2wd, 351w, C6, 3.55's. I don't know the GCWR for my truck, but I'm sure I was over it. On another trip across the scales, the unloaded truck by itself was 4025lbs with me in it and two full tanks of fuel. Needless to say, the truck managed the load well, but it was straining.
Load capacity - as much as the tires will take! That's what I say
Meh not quite.
OP max before you get in trouble is like 26,001. I have mentioned this several times but the skill of the driver is the biggest factor. With 4.10s and a 460, I would not worry carrying 4-8 tons or so. But in doing so I would max sure to weight it out on the cat scales prior to hooking up my trailer (fully loaded fuel etc) I would then weight my trailer, and then I would add my load. If I wasn't over 26k pounds I would pry try it. I would make sure brakes and everything were brand new and take backroads etc. Some people here have grossed 30k with their trucks and I know that these fords can do it.
Keep in mind that before you try and tow anything of reasonable mass, you're gonna need to replace some parts like U-joints, brake components, etc. if you want to have a happy trip. Also remember that you have a 24-year old transmission...make real sure it's in good shape before you start pulling any big loads. Fluid change, filter change, etc. Check the rear axle too, making sure it has enough gear oil in it.
And I'm just gonna say this.....but maybe these trucks could pull 4-8 tons. But can it do it safely, or without tearing the truck up?
