I bought some fel pro head gaskets for my 79 351 M motor and on both of them they closed the water jacket port off on one end of the gasket??? does any body know if those gaskets are a manufacture era???? fel pro 8347pt-1 the head gasket i took off has the same ## but the water jacket port is open so the water can circulate thu the head???????? help any body
thank you to all that respond
does it help to flip them around? i built mine not too long ago, but i also rebuilt about 3 other motors since then too and i know i came across this problem on one of those, i just dont remember which one.
it would not help on fliping them around for the reason of the ports that match up to the head and block ?? im digging around and contacted fel pro about this --but no reply yet?? any more help would be kind---
so that means that my water ports on the back of my heads will not circulate water thru the teer drop port from the block to the head??? the other gasket i took off has the same felpro## but it has the open ports in the back so the water can circulate ???
does any body now why this is ????
i just took a very old <a href="http://motorhaven.autoanything.com/">351m </a>apart. i checked the head gaskets and found that both heads have the front, lower, teardrop ports blocked. the rear teardrop shaped ports are open.
some ports are around 3/8" but the gasket may only have a 1/8" hole.
interesting question. i wonder why the gaskets are open, closed and restricted on others?
in any event, i would beleave the gasket is ok and is just some form of delebrate variation. i have a lot of confidence in fel-pro.
You only need the front top opening for the water to circulate.
if you look at the gasket is says Front on one side.. just make sure it's points to the front .. one gasket is right side up and the other is right side down ....
shazam ok i can deal with that but do you know why the fel pro did a design change??? i have the gasket that came off the bronco and its a felpro same ###with all ports open and the knew felpro with the same ###withonly the front water ports open???? im just wondering when they molded these gaskets they forgot to insert the proper dies and there just passing them on to us ????? im waiting on felpros response to this---and when i get it i'll post it to all
any more help will be kind thanks to all so far for you information
Well if it's a design change then it's been awhile since they changed it .. All the motors I build using the FelPro gaskets they never had holes on both ends just the front ..Granted Ive only been building motors for about 5 years, but that when I started using FelPro gaskets...
Here's the low down why the front water ports are sealed off on the head gasket's
This is a quote from FEL-PRO
For the reason to much water circulates in the front of the block --by sealing off the ports by using the gasket to stop the flow of water thru the tear drop ports between the head and block --more water can now be diverted to the back of the block where it is neaded-- in the past their was not enough water being circulated to the back of the block --this was acheived by a desin change----FROM FEL- PRO
