Knocking
Old Jun 2, 2011 | 07:13 PM
hardy541's Avatar
hardy541
Knocking
I bought a 1986 F250 with a 351 and a 4 speed two weeks ago. It ran great for two weeks and then i drove it to school today and it started knocking. We checked timing and timing is all good. we believe the camshaft broke. Any ideas?
Old Jun 2, 2011 | 07:21 PM
ctubutis's Avatar
ctubutis
What is making you think you have a broken camshaft?
Have you put a real oil pressure gauge onto it yet?
Old Jun 2, 2011 | 09:12 PM
hardy541's Avatar
hardy541
no i have not done the oil pressure but it does not appear to be a rod knocking. When you are at idle you can tell its knocking but when the rpms get up above 1500 it gets real bad an sounds like its gonna blow.
Old Jun 2, 2011 | 09:20 PM
AstroFab's Avatar
AstroFab
Ok stop doing that.
Time to tear into it. Cams don't just break, so it's not likely.
Pull the intake/distributor and look around inside. Look at the pushrods, make sure they are straight. Look at the distributor gear make sure it's not sheared. Pop off the water pump and timing cover and see how the timing chain looks.
Drain the oil, see if anything other than oil comes out of the drain hole.
If you haven't seen any damage so far, take it further. Remove the oil pan, look at the bottom end. Could be something as simple as the oil pump pickup rattling around in the pan, or something more serious.
If you haven't seen anything this far...time to pull the engine.
Old Jun 2, 2011 | 09:24 PM
ctubutis's Avatar
ctubutis
If you don't have a stethoscope, you can use a piece of rubber heater hose or some such to try and find the location of the noise.
You might remove the valve covers and see what you find underneath, a guy out here (CamoLaw) brought his 6-banger truck to my house a few weeks ago with a bad noise, turned out one of his pushrods made its way out from underneath the rocker arm:
Todd Fuller
23
Aug 11, 2014 12:31 PM
kdbbmanton
2004 - 2008 F150
Sep 22, 2009 06:18 PM
straightsix4x4
Offroad & 4x4
Dec 4, 2008 09:42 PM
Rocker7700
24
May 18, 2008 10:19 PM
sparkknockerin sc
Modular V10 (6.8l)
19
Apr 27, 2004 07:33 PM
