average temps needed
Old Jun 2, 2011 | 01:01 PM
bergy 2000's Avatar
bergy 2000
I have a 2000 v10 excursion 2wd and 4:30 rear gears. I am using a scan gauge II and wonderng about some things.
I believe I have it set up to monitor the RPM,TFT CHT,MPH,
What should the CHT temp be when running the A/C in 93Deg weather and towing?
Is this the best way to monitor the coolant temp?
I tow 32' TT and and have installed a 6.0 trans cooler. My hottest temp to date is 185. Does that sound ok with the 6.0 or should I be running cooler?
What are some tips for using the trip feature on the scan gauge II?
Old Jun 2, 2011 | 01:41 PM
mrad's Avatar
mrad
What is your TFT range?
My coolant runs 180-190 in the summer towing a 6,000 lb TT.
Old Jun 2, 2011 | 03:54 PM
gr8scott72's Avatar
gr8scott72
I tow 32" TT and and have installed a 6.0 trans cooler. My hottest temp to date is 185. Does that sound ok with the 6.0 or should I be running cooler?
Run that trailer in some heavy stop-and-go traffic and you'll see tranny temps over 200°. Well, at least here in hot Mississippi I do. (It was 100° here today.)
You're fine up to about 220° on the tranny. Then you need to be finding a place to pull over.
I'd be more worried about the tranny temps than I would the CHT as long as they are fairly constant and not spiking up.
Old Jun 2, 2011 | 07:13 PM
bergy 2000's Avatar
bergy 2000
I was wrong its not CHT It is just WT (water temp) What temps should I see from the Water Temp Gauge? 200 or just over was the highest I saw on a 95degree day pulling with the A/C blasting and stop and go. Most of the time she was sitting around 190-195. does this seem normal?
As far as the TFT it usually is around 170-180 unless I am in stop and go and then it may go up to 185. This is on a 95 degree day with the air blasting and pulling a 8000+ lb TT for over an hour. If Im not pulling, the temps dont get that high, maybe 165 or so. Before when I had the stock v10 cooler in it I saw 200 on a 70 degree day. I cant imagine what that would be on a 100 degree day in stop and go. I can say the 6.0 cooler did make a pretty good differance in temps.
Old Jun 2, 2011 | 07:37 PM
gr8scott72's Avatar
gr8scott72
Sounds about right to me.
Old Jun 2, 2011 | 09:08 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
185°F is cool. There is nothing to worry about. You might get hotter if you trade that 32 inch trailer for a larger one, though....
(" means inches, ' means feet. Just pulling your chain...)
Old Jun 3, 2011 | 03:14 AM
bergy 2000's Avatar
bergy 2000
My mistake, hit the shift key by mistake...
Old Jun 3, 2011 | 09:16 PM
gr8scott72's Avatar
gr8scott72
Driving around today WITHOUT a trailer, my tranny fluid temps hit a high of 202°!!!
It was a brutal 101° outside though and that was stop and go traffic. Once out on the interstate, it dropped to about 190°.
Water temps were 190°-195° pretty much that whole time.
JerrySLC
1997 - 2003 F150
May 21, 2025 08:59 PM
mikekp
1997 - 2003 F150
Apr 19, 2024 05:44 PM
John Hill
Testing.....
Dec 18, 2016 08:53 AM
cworthington
2004 - 2008 F150
Sep 26, 2015 10:09 AM
jrvance7
Modular V8 (4.6L, 5.4L)
Jul 27, 2011 05:13 PM
