Get the mechanic to do a clear hose test..........or do it yourself ensure you put a curl/pigtail loop in the hose so you can identify the direction of leak.
There are numerous air intrusion points, one being the fuel heater connector (black) area on top of the Filter header......
I happen to have my sending unit sitting on my table at home. I will take a picture and post it for you. I wonder if I should change my check valve while I have it out. It doesn't seem stiff or deteriorated, though.
