No Power
Old May 31, 2011 | 07:26 PM
shawbran's Avatar
shawbran
No Power
I just purchased a 1994 Ford F Super Duty. The truck is a 5 speed with a 460 EFI. Seems like the truck is low on power. It has a 4.63 rear end. When driving up hill's I lose 10 - 15 MPH, with downshifting into 4th gear. To me the truck should climb right up them with little speed loss. Here's what I have done so far:
New Plugs
New Wires
New Distributor Cap
New Rotor
New TFI module
New Fuel Filter
Lot's of injector cleaner
Any ideas where to go from here??
Old May 31, 2011 | 10:36 PM
Conanski's Avatar
Conanski
Tire size?
Codes present?
Ignition advance?
Fuel presure?
Old May 31, 2011 | 11:15 PM
Edgethis's Avatar
Edgethis
Could be a clogged cat.
Old Jun 1, 2011 | 08:24 PM
shawbran's Avatar
shawbran
The truck didnt have a cat on it when I purchased it. I aint throwing any codes. The fuel pressure is in the low 40's.
Old Jun 1, 2011 | 10:17 PM
Edgethis's Avatar
Edgethis
Are there any other symptoms? Does it run hot?
Old Jun 1, 2011 | 10:25 PM
shawbran's Avatar
shawbran
I can't find any other problems temp runs normal I'm at a lost.
Old Jun 1, 2011 | 10:26 PM
1992ford302's Avatar
1992ford302
maybe advance the timing a hair, or could be the motor is full of junk and needs a good cleaning... I would get a can of seafoam drive with it for est 50 miles and do a oil change on it, the slug could be holding you back some... Just some ideas but let us know if you figure it out!
Old Jun 1, 2011 | 10:30 PM
Edgethis's Avatar
Edgethis
Whats the mileage? Is it eating any oil/ blow-by maybe? Have you done a compression test on the cylinders?
Old Jun 1, 2011 | 10:37 PM
1992ford302
if the cylinder test numbers are low after a compression test put a cap full of oil in the spark plug hole and see if that made the test number go higher.
lespeggy
32
Apr 3, 2020 07:09 PM
k4wtd
Aug 29, 2013 08:11 PM
76f350spercamprspeal
Mar 31, 2010 03:41 PM
jason05
Feb 23, 2008 07:35 PM
Chris in SW Va.
Sep 11, 2004 04:36 PM
