Been trying to diagnose a WOT bog condition on my truck. Got the timing set spot on, pulls a solid 20" of vac at a very smooth idle. I've watched some of the Holley tuning videos on YouTube, but still haven't quite figured out exactly what my truck needs.
When I nail the throttle from cruise it just chokes down and damn near stalls unless I let off. Kinda scratchin' my head on this one.
FYI: Holley 4150 Vac secondary 600cfm.
Edit:
I took the vacuum secondary apart a few minutes ago, to see what spring was in it and maybe figger out if I need to step up to a heavier spring for the truck. Turns out I've got a black short spring in there, which IIRC that should be the heaviest spring that holley has. Maybe I'm not getting enough pump shot, or I need to step down to a lighter spring so that it'll act right.
I'm still confused here, guys any help would be appreciated.
Nope, this one only has a single accel pump on the front bowl. I did however find out something else while tinkering today, that my accel pump has a white cam installed in the first slot/hole. I bumped that up to the second hole, and how instead of stalling entirely it will hesitate for a split second and then rev up.
I'm thinking I still might need a change of secondary spring, and perhaps a cam set, and while I'm at it I might need to change the accel pump itself.
It still sounds like the accel pump. Try a green cam first installed in the first hole and
see how it does. If it still has a bog try the second mounting hole and test again. You
might use the next lightest spring in the secondary vacuum but that wouldn't affect
the bog unless your carb is way too lean. Do one thing at a time and see what difference it
makes and then move on to other changes one at a time. Good Luck.
Reason: fix line breaks
It still sounds like the accel pump... You might use the next
and see what difference it makes and then move on to other
I agree; the secondaries aren't going to open until the engine vacuum says they can open.
I'd also be pokin' around the accelerator pump area.
