Carb guru's...step inside please
Old Aug 22, 2010 | 12:28 PM
Buckeye Rich's Avatar
Buckeye Rich
I was changing the spring in my vacuum secondary carb, to try and eliminate a bog. Anyways, I tore the vac secondary diaphragm and need to replace it. Holley sells 4 different sizes. Anyone knew the correct one?
The carb is the factory 4bbl carb on my 86 F250 351w. I believe the carb to be a 4180c. The list number on the carb is 50264-1.
Thanks
Old Aug 22, 2010 | 01:10 PM
Old Hickory's Avatar
Old Hickory
I think one for a Holley model 1850 600cfm 4bbl will fit.
Old Aug 22, 2010 | 01:38 PM
Franklin2's Avatar
Franklin2
Did you know the aircleaner will affect how the secondaries open on a Holley? A restrictive air filter/cleaner assembly will make them open faster, and a more open filter system will make the secondaries open more slowly. Do a test run without the aircleaner and you will see what I mean.
Old Aug 22, 2010 | 04:08 PM
Buckeye Rich
Ok, the correct Holley part number is 135-4. It is the same as the Holley 1850 carb, just like Old Hickory said.
O'Reilly's had one is stock. The carb is back on the truck. All is good. Still have a slight delay/hesitation . But it's much better.
Old Aug 22, 2010 | 09:49 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
if it's just off idle it could be the accelerator pump adjustment.
If 2000 rpm or so, you could try a heavier spring.
Holley #20-13 kit:
http://www.holley.com/data/Products/...199R8219-2.pdf
Old Aug 23, 2010 | 12:13 AM
kermmydog's Avatar
kermmydog
I run a black spring on my 4160 600 CFM. That is the heaviest spring.
hooler1
Feb 28, 2015 09:08 PM
68Ford4Life
20
Jan 18, 2012 04:26 PM
79FordBlake
Sep 14, 2010 12:59 PM
turtle13b
Aug 31, 2010 11:00 AM
Fordenthusiasts
Aug 26, 2007 11:59 PM
