A/C Problem
Old May 31, 2011 | 12:37 PM
tritonman2001's Avatar
tritonman2001
A/C Problem
Ok guys here is what I have e99 F-250. Freon is fully charged, at idle it only cools to about 75 degrees, and driving it cools to 50 degrees. Outside air temp is 93 degrees. Fan clutch works, high and low side pressures are good. Condensor and evaporator core are both clean. Any idea what is going on.
Old May 31, 2011 | 12:43 PM
riverrat41's Avatar
riverrat41
Check this out
https://www.ford-trucks.com/forums/5...ml#post4464164
SpringerPop's Compressor Clutch Air Gap
Old May 31, 2011 | 01:06 PM
nlemerise's Avatar
nlemerise
You might want to consider installing a valve in the heater hose to stop flow of hot water into the cab, in addition to setting the clutch air gap.
Old May 31, 2011 | 01:12 PM
riverrat41's Avatar
riverrat41
Originally Posted by nlemerise
Good suggestion Neal.I have that and it works.
Old May 31, 2011 | 01:20 PM
tritonman2001
the clutch gap is correct, that is one of the first things I did this year as a preventitive check. the valve on the heater hose is a good idea, but does not explain the 25 degree difference from idle to driving.
jgdrcr
Aug 13, 2014 04:36 PM
onequicksportster
Jan 10, 2013 08:49 AM
clhart426
Dec 7, 2010 09:32 PM
Texas Mad Man
Jan 11, 2009 11:00 AM
reamer
Jul 31, 2004 03:27 PM
