4R70W Questions
Old May 30, 2011 | 11:22 PM
masterofnone's Avatar
masterofnone
4R70W Questions
So as I understand it there were two different ones in the 97 F150's... Can't remember the ID's but I'm curious as to what the difference is between them? Was it the valve body or were there several adjustments made in the overall design?
Here's why I ask. Mine is about done... shudders on shifting... I've got a buddy that's got one from a Mustang with 20k on it but it's the other ID tag. After gutting it and using my extension housing and shaft I shouldn't have a problem should I? If the valve body is the difference then I could simply use mine couldn't I?
I've checked it all out and the harness is the same and overall looks like a direct swap aside from having to gut it and get it all back in. This shouldn't be a problem as it will all be laid out in order and an assistant will be taking pictures of absolutely everything.
ALSO: What are the odds that I could take a manual trans out from behind a 4.2L and toss it in mine? It's at the local junkyard and complete. I just miss having a manual.
1997 F150 4.6L 4x4 Auto 226k+ Ex. Cab
Old May 31, 2011 | 05:55 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The chances of a transmission from a 4.2L bolting to your 4.6L are exactly zero. The bolt patterns are different.
When assembling a transmission it is more than photographing everything and putting it back the same way. There are several measurements that have to be taken and selective thickness washers to maintain the proper clearances. You can do it without these, but plan to do it again soon while replacing damaged parts.
Old May 31, 2011 | 02:27 PM
masterofnone
okay that's understandable and thank you for the info. How about the differences in the two ID's? I still haven't found anything explaining the differences.
Bubba Jones
31
Jul 2, 2016 02:06 PM
Thomas Boersma
Mar 6, 2016 10:11 PM
tonytwotimes
Escape & Escape Hybrid
Aug 14, 2015 11:10 AM
Constant_Vigilance
17
Jul 21, 2015 01:02 PM
lvin4jc
Sep 19, 2014 03:25 PM
