c6 id help
Old May 30, 2011 | 08:48 PM
Toivul's Avatar
Toivul
8th Gear
c6 id help
I need some help identifying this c6 I have. I have no information on the truck it came out of and it didn't have a tag. I was thinking about putting into a '77 ford Bronco with a 302 or selling it. I'm pretty sure it is a big block 335 from what I can find on this site and I think it is a '77 vintage. I would really appreciate it someone could chime in with their two cents worth. It has a NP205 attached.
Old May 30, 2011 | 09:30 PM
85e150's Avatar
85e150
D7 is 1977.
Image number two shows the bell to engine pattern, which matches the 335/385 pattern shown here when you scroll down:
FordFE Forum Faqs
It sounds like you may have already found that one.
As far as other info, a C6 is a C6--ratios are the same, some differences in the input shaft and TCs to be watched for, but this info from a TC & trans seller indicates the crank pilot is the same SBF, 335 & 385 series.
TCI® - Sorry...
So it "should" work for any any 335/385 except those few 400s with the SBF pattern. But not the 302.
Old May 30, 2011 | 10:23 PM
Toivul's Avatar
Toivul
8th Gear
Thanks so much. I guess it's off to the classifieds for this.
Old May 31, 2011 | 11:28 AM
mark a.'s Avatar
mark a.
It's a 429/460 or 351M/400 trans. It won't bolt to a 302. They come in short tail or long tail. That one is a long tail & I don't think it will work in a short wheel based truck or Bronco.
majkthreads
6.7L Power Stroke Diesel
28
Jul 1, 2013 11:48 AM
majkthreads
28
Aug 28, 2012 07:01 PM
karatedavid
Dec 18, 2011 07:05 AM
bryanswens
27
Sep 25, 2010 11:33 PM
BioHazrdMan
63
Oct 28, 2008 09:21 AM
