5.0-302 Conversion
Old May 30, 2011 | 08:31 PM
teched's Avatar
teched
5.0-302 Conversion
I have a 1987 5.0 that converted back to carburated and installed points ignition. Runs pretty good but I have the ports on the back of the heads that I think the EGR tubes bolted onto. I am not seeing any exhuast comming out of holes but I should probably block them off or hook them into something. Or should I just leave them open? Thanks -Ed
Old May 31, 2011 | 01:46 AM
Beanscoot's Avatar
Beanscoot
Those passages might be clogged with carbon, but it is a good idea to plug them. They are threaded 5/8" coarse. Allen drive set screws are ideal for this. It might be a bit difficult to start the screws if the threads are carbonned up.
Old May 31, 2011 | 09:32 AM
Conanski's Avatar
Conanski
There would be a gawdawful sounding exhaust leak with the engine running if these ports were open, so if you don't have this problem I'm guessing they are already plugged. A little piece of mirror and a flashlight should let you see back there.
tilelayher
EcoBoost (all engine sizes)
Dec 13, 2013 09:02 AM
tbart16
Dec 29, 2011 01:41 PM
mtcrss14
Nov 6, 2007 09:40 PM
MScotty
Oil & Lubrication
Aug 23, 2007 06:47 AM
00bucker
Feb 22, 2007 06:47 PM
