Sponsored by: Real Truck
Rear axle ID???
Old May 30, 2011 | 05:02 PM
tinman52's Avatar
tinman52
Welder User
Rear axle ID???
Hi all, I'm trying to replace the pinion yoke and seal on my truck......it's a '99 SD SC 4x4 with 5.4 and auto. Tag from cover reads....S 156 C, then 4 10 10 5 8J11.
Been told it's either a dana 50 or sterling 10.25. So which is it? Need to ID it so I can get parts......Thanks.
Old May 30, 2011 | 05:25 PM
Zedrive's Avatar
Zedrive
Rear from your numbers: Sterling 10.5", 4.10 ratio, Open diff.
Front Dana 50 in 99.
Old May 30, 2011 | 05:40 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I was pretty sure the rear was a Dana 60 until 2001 or so. But I could be wrong.
Old May 30, 2011 | 10:53 PM
tinman52's Avatar
tinman52
Welder User
OK, according to the tag it's a sterling 10.5. I thought they started using that rear in '01 or '02? Mines a '99...seems odd....
Old May 30, 2011 | 10:54 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Thats what I thought too. Maybe it was swapped?
I'm assuming you dont have a DRW, because those were always the Sterlings.
Old May 30, 2011 | 11:15 PM
tinman52's Avatar
tinman52
Welder User
Maybe swapped...I haven't had the truck too long. Everything looks original though. No dually, SRW F250 shortbox...
Old May 30, 2011 | 11:18 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Yeah, I am fairly sure they Sterling went in during 01 or 02.
Old May 31, 2011 | 12:08 AM
p-nut's Avatar
p-nut
Sterling is actually the city the axle is made in. Visteon is the name of the company that produced the rear axle for Ford.
F250-350 SRW from '99 up use 10.50" "sterling" rears.
Below '99 use 10.25" long pinon "sterling" rears (but are basically interchangeable with 10.50" from '93-'98. I have 10.25" gears in my 10.50" axle right now).
'92 and below used "sterling" 10.25" short pinion.
DRW use a dana rear axle, never a sterling. It was either D80 or D110 depending on year.
'99 front axle was a solid Dana 50 (dana 44 center section with dana 60 axle tubes), after '99 it was replaced with the dana 60.
Before '99 it was a dana 50 twin traction beam and most parts are interchangeable with the solid axle dana 50.
Old May 31, 2011 | 10:42 PM
tinman52's Avatar
tinman52
Welder User
p-nut, thanks for the info.....this is why I keep coming back to this forum!
Old May 31, 2011 | 10:43 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I was very backwards..
6.9idiatsturbo
May 13, 2016 02:25 PM
gadiedrick
Jan 20, 2016 06:25 PM
dixie460
19
Dec 6, 2014 09:32 PM
beachpony
Nov 8, 2012 03:26 PM
HeathJohnson
Mar 29, 2012 06:30 PM
