Decode
Old May 29, 2011 | 11:23 PM
blloyd's Avatar
blloyd
Decode
I know how to decode the VIN # but still need to learn to understand the sticker on door jam.
My truck at bottom has 133-F142-LK4-K-19-2-E L
Any help out there ?
Old May 30, 2011 | 01:03 AM
donnor's Avatar
donnor
No need for Dan Brown's DaVinci...
133-->133 inch wheelbase
F142-->half ton series, GVW range, & 2 vs. 4 wd
LK4-->body, cab (regular or super)
K-->transmission type
19-->3.55 ratio open carrier differential
2-->tape code (body side trim)
E L-->spring code
Ford shop manuals provide full details of the various options & their respective codes in the ID section near the front.
dn.
Old May 30, 2011 | 04:54 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What year, series is this? These codes apply to multiple years.
F142 is F150 related, but your profile says you have an '88 F250.
Old May 30, 2011 | 08:04 AM
blloyd's Avatar
blloyd
The 88 F-250 is a former truck and I now have an 87 F-150 4X4 !
Old May 30, 2011 | 09:03 AM
NumberDummy
My 1987 F150 4WD at bottom has 133-F142-LK4-K-19-2-E L
133" Wheelbase.
F142 = F150 4WD, 133" W.B. / 6,250 lbs. Gross Vehicle Weight Rating.
LK4: LK = Chestnut Cloth & Vinyl // 4 = Styleside Pickup.
K = C6 Cruise-O-Matic.
19 = Ford 8.8" Rear Axle / 3.55-1 / non Limited Slip / 3,750 lb. Rear Axle Capacity.
2 = Stripe Code.
EL: E = Front Spring Load Rating: 3,215 lbs. / L = Rear Spring Load Rating: 1,854 lbs.
Old May 30, 2011 | 02:02 PM
blloyd's Avatar
blloyd
Thanks !! Does it say anywhere what color the truck is ?
Is has 9N and 9T hwere is has the color !
Old Jun 1, 2011 | 12:56 AM
NumberDummy
Thanks!! Does it say anywhere what color the truck is? It has 9N and 9T where the color is!
9N = Medium Desert Tan Metallic // 9T = Light Chestnut.
black*shirts
May 22, 2013 05:51 PM
trucker101
Jun 6, 2009 10:01 AM
johnboy427
May 22, 2009 10:19 PM
voltson
Jun 6, 2007 10:14 PM
killerkjn
Oct 4, 2004 09:18 AM
