Offroad & 4x4
why so dead?
Old Jun 1, 2011 | 11:28 AM
  #46
fatdan460's Avatar
fatdan460
it runs great. 50ish miles on a full rebuild, good power, c-6 205 d44 d60rear. 3.50 gears open diffs i had a set of geared and locked one tons and 40's lined up for it but the guy dicked around and didn't pull them out of his truck quick enough for me and i ended up spending the money on bills, i suck at holding on to cash.
as to the gas tank, seriously just buy a new one. restoring them is pointless. i basically ended up wasting a metric chit ton of time on mine and thought it was good to go. let it dry out for a day after i cleaned it out and came to find about 3 pounds of rust and powdered rust had come off the inside while drying. repeated cleaning resulted in the same outcome. basically once a tank is fubared it is done for.
Old Jun 1, 2011 | 11:40 AM
  #47
alpha/omega's Avatar
alpha/omega
Eastwood makes a coating for the inside of the tank which is damn good BUT its expensive and a total waste on a stock tank. That being said I used it on my tank after some modifications and it seems to be holding up perfectly.
Old Jun 2, 2011 | 01:35 AM
  #48
Prozon's Avatar
Prozon
I'm fine with buying a new tank if it comes with a sending unit, but I doubt it does. I was going to order one, but ordering the sending unit AND a new tank, really sucks.
Old Jun 2, 2011 | 02:06 AM
  #49
fatdan460's Avatar
fatdan460
chances are the sending unit will be fine, just make sure the float still floats and that the pickup tube isn't all crusted up inside. you should be able to get away with a new tank and filter for the old sending unit/pickup tube.
Old Jun 2, 2011 | 07:08 AM
  #50
hav24wheel's Avatar
hav24wheel
Speaking of gas tanks..
Anyone ever take the one out of the cab of a 70s Ford, and mount it in the front of the box? I was thinkin about more fUel capacity for the 94.
Old Jun 2, 2011 | 09:54 AM
  #51
alpha/omega
Id get a cell rather than a factory in cab tank.
Old Jun 2, 2011 | 10:07 AM
  #52
hav24wheel's Avatar
hav24wheel
I was thinkin that tank due to it taking up the least amount of front to back bed space in a already small bed.......... But I guess I could find a wide tall skinny cell...
Old Jun 2, 2011 | 10:29 AM
  #53
fatdan460's Avatar
fatdan460
i've seen some pretty thin transfer tanks on farmer trucks. probably not cheap but maybe look into them.
Old Jun 2, 2011 | 10:36 AM
  #54
hav24wheel's Avatar
hav24wheel
Ya, thoes are spendy... 200$ for a liTtle "cheapy"
Old Jun 2, 2011 | 10:42 AM
  #55
Prozon's Avatar
Prozon
Dan my sending unit already has issues, so I was planning to replace it. I didn't think that the tank had any problems until I dropped it to weld on the frame.
Old Jun 2, 2011 | 10:45 AM
  #56
hav24wheel's Avatar
hav24wheel
Well, maybe u need a diff rig.
Old Jun 2, 2011 | 10:46 AM
  #57
alpha/omega
damn non-refreshing browser
or build one. = build a cell to fit your truck.
Old Jun 2, 2011 | 10:55 AM
  #58
hav24wheel's Avatar
hav24wheel
Ya........... Truf
Old Jun 2, 2011 | 10:57 AM
  #59
alpha/omega
P-zit, wtf is wrong with your truck that you feel the need to weld your frame?
Old Jun 2, 2011 | 11:05 AM
  #60
hav24wheel's Avatar
hav24wheel
Rusted. Shot.
