49 F3 Flathead Stalling
Old May 29, 2011 | 09:02 AM
bailegb's Avatar
bailegb
My 49 F3 has a 226 flathead with the original 4 speed tranny. It starts right up and runs ok, but as I am approaching a stop sign and double clutching down, the engine dies. It seems if I keep the revs way up it is ok, but that is tough to do when you are trying to stop a big truck that has stock brakes. Any ideas of what I should look at first?
Old May 29, 2011 | 09:29 AM
ALBUQ F-1's Avatar
ALBUQ F-1
If it only does it when stopping, check your float level.
Old May 29, 2011 | 09:35 AM
tinman52's Avatar
tinman52
Welder User
Yep, check float level......and check around carb for vacuum leaks. Does the truck have a hydrovac? (brake booster) You may have a vac leak there also....
Old Jun 19, 2011 | 03:04 PM
bailegb's Avatar
bailegb
Both you guys were right. I tore down the carb and readjusted the float and the problem seems fixed. I am sure that beside the float I had a few leaks also. Thanks for the advice.
whitley
Jun 10, 2012 01:41 PM
55 f350
Mar 26, 2008 09:15 PM
49F1Flathead
Jan 4, 2008 11:37 AM
texan2004
Flathead V8 & Flathead 6
13
May 26, 2005 11:24 PM
restoringmy46
Dec 16, 2004 10:23 PM
