i dropped my oil pan today to r&r the gasket (leaking) i was surprised at how clean the inside of the pan was no sludge at all . problem i did find was a metal c clip about the size of a quarter . i am not fimilar with the fe engine anyone recognize this ?? the wing nut is there just for size reference.
thanks in advance
mike
oh other thing i saw was lots of back forth play on the rods , is this normal ?
and timing chain has probably 1/2 slack .
looks like a rebuild is in my future (near future)
Question
does the piston travel down far enough to let the retainer fall out ? i am thinking no
so how did this get there ?or are the retainers on the inside close to the rod ?
Well thats not good, like John already said thats a wrist pin retainer! I lost 3 of them from the improper install at machine shop. There is a rounded side and a square cut side and they must only go in one way. Good news my engine ran for almost 20,000 like that made a lot of smoke towards the end and ruined the block as it cut perfect lines deep into the walls but plan on a rebuild soon.
my truck does blow smoke , thought it was just valve seals needing replacemet.
guess i'll crank engine over by hand and see if i can see and cylinder wall damage.
Mike, take that piece to a motor rebuild/machine shop and see if they can match it up. I'm sure they can figure it out but I think you already know what it is.
