SLOPPY STEERING
Old May 28, 2011 | 07:47 AM
MySonsFord's Avatar
MySonsFord
SLOPPY STEERING
You guys hit a homerun with my last issue, here is a new one. Drove my sons 79 F150 2 wheel drive (351) and the steering is really sloppy. In that you turn the wheel alot before the whells actually turn. Thought maybe tie-rods, but when I looked under the front end, I didn't see the tie-rods that I expected to see. Never owned a Ford till now, only Chevys, so I am not sure what part(s) need to be inspected and replaced to fix this. Thanks for any advice, and don't get on me to bad for always owning Chevys. just seemed like whenever I searched the classifieds when I needed a new work truck. Chevy was was the only choice. Ford guys must hold on to their trucks.
Old May 28, 2011 | 08:33 AM
cigarxtc's Avatar
cigarxtc
To fix my sloppy steering i first tried tightening down the worm gear screw on the steering gear as far as it would go. It helped a little but was so worn after 30+ years that eventually i had to replace the whole steering gear unit. That helped tremendously. Then I also found slop in the steering tie rod arm ball joints. After replacing those my truck rode straight and true. Also, after replacing all those parts i got it aligned. Highly recommend alignment after changing all those parts.
MontanaMan
Oct 26, 2011 06:26 PM
laka
Mar 22, 2008 07:23 AM
ATC Crazy
1997 - 2003 F150
Feb 11, 2006 11:42 AM
plitz.....
19
Apr 25, 2004 08:17 PM
parr4
Feb 10, 2004 12:38 PM
