engine swapping
Old Dec 4, 2002 | 08:58 PM
jfreeman's Avatar
jfreeman
Post engine swapping
Does any know if a 351m carburated engine from a 1986 f250 4x4 can be exchanged into a 1989 f250 4x4 with a 351m EFI, with little or no problems with swapping parts over. If not does any know where I can find this information. Thanks for the help.
Old Dec 4, 2002 | 09:39 PM
steve83's Avatar
steve83
engine swapping
You'll have a several issues to take care of, but why would you want to? An EFI runs better & is easier to maintain.
Old Dec 4, 2002 | 10:31 PM
Brian460's Avatar
Brian460
engine swapping
If the motors are the same it would be relatively easy to do, however there was no EFI 351m. There is a EFI 351w, but it is not the same bellhousing as a 351m.
I might be wrong but, I think that the 351m didn't get used after 83 so the '86 might also be a 351w. Let us know and we can go from there.
Old Dec 5, 2002 | 06:44 AM
lr's Avatar
lr
engine swapping
brian460 is right, ford stopped putting using the 351m in the early eighties. i'd double check your motor to make sure if its a 351M. and if indeed it is you'll have to have to change the bellhousing in the 89 model because it should be a windsor, the 351M using a big block bellhousing bolt pattern and the 351 windsor uses a small block bellhousing bolt pattern.
LR
Old Dec 5, 2002 | 12:00 PM
jfreeman's Avatar
jfreeman
engine swapping
[updated:LAST EDITED ON 05-Dec-02 AT 01:03 PM (EST)]The truck may have a 351w I have not taken a close look at the motors I bought a 1989 with an engine rap and I have a friend with the 1986 351 I want to keep the efi on the truck just basicly take the 86 motor as a long block because it has low mileage the truck is made in canada thanks for the help.
Old Dec 5, 2002 | 12:44 PM
Hit Man X's Avatar
Hit Man X
engine swapping
The 351/400M motors have the 460 bellhousing on there. I believe they were made from the mid 70's to the early 80's. That being said, what you wanna do won't work on a Windsor based motor (289/302/351).
Not only that, the intake, heads, etc will not work either. I guy I used to know had a '77 Bronco with a 351M and a C6...it was damn near impossible to get parts for that oddity.
Old Dec 5, 2002 | 11:51 PM
Brian460's Avatar
Brian460
engine swapping
Go take a look at the '86 if it is a 351M it will have the thermostat housing on the block, if is a 351W it will be on the intake. Let us know which one it is.
To another reply I would hardly call a 351m/C6 combo an oddity as is was used extensively from 77 and up in trucks and some cars.
Old Dec 13, 2002 | 06:31 PM
1988 Ford 150 4x4's Avatar
1988 Ford 150 4x4
engine swapping
Old Dec 13, 2002 | 09:54 PM
jfreeman's Avatar
jfreeman
engine swapping
>the intake. Let us know which one it is. The thermostat housing was on the intake manifold, but the motor turn out to be a 460, thanks for the help.
>and some cars.
