Starting issue
Old May 26, 2011 | 07:17 PM
jpayne10's Avatar
jpayne10
Starting issue
1988 F250 4x4
the PO had installed a toggle switch for the Fuel Pump. It was an anti-theft idea. anyways, i was told that i have to turn it on about 5 seconds before cranking. and idk what problem im having but 1/2 the time i want to start the truck, it will almsot start then die & not start again unless i let it sit for a while.
any ideas?
351w
Old May 27, 2011 | 06:12 PM
jdeeg4276's Avatar
jdeeg4276
Starter relay?
passenger fender by battery.
you can jump both terminals and see if it starts.
Maybe check the starter silonoid and when cranking checking if you have power on both sides of the silonoid.
if power is there on both sides, and its not starting well then you found your problem.
Old May 27, 2011 | 07:39 PM
jpayne10's Avatar
jpayne10
cranks, but no spark. found that out after i worked 16 hrs yesterday
Old May 27, 2011 | 08:03 PM
Duct Tape Racing's Avatar
Duct Tape Racing
does the pump run consantly?
Old May 27, 2011 | 09:07 PM
jpayne10's Avatar
jpayne10
with that toggle switch on, yes
Old May 27, 2011 | 09:10 PM
ostrx250's Avatar
ostrx250
welcome to fte
turn the key on then flip the switch can you hear the fuelpump run??? it will only run for like 10 seconds check the pressure on the fuel rail. you might even pull the ign module on the dist if it fails you loose spark. youll need a special tool to remove it well that gives you a starting point
jshort12
17
Jan 9, 2015 07:23 AM
crestfallinman
Aug 4, 2011 04:51 PM
jimbomac22
Sep 28, 2010 08:38 AM
clipper1
Nov 16, 2005 02:16 PM
ford4me_1
Oct 18, 2000 07:22 AM
