another IDI record breaker! 321 HP & 558 ft-lbs of torque! DPS Pump & Injectors
  #31
Old 05-27-2011, 01:52 PM
ah1988's Avatar
ah1988
ah1988 is offline
That is the best sounding idi ever !
I am going to e-mail this to my aunt, who dosent like trucks she thinks they dont have any muscle behind them , yea right !
Were can you get moose ip's, ive been looking around and havent been able to find any, Not that i am getting one, but if i run into the funds suddenly someday i just might give them a try.
Since we are on the ip's, subject do standyne ip's have the manufacturing date stamped on the pumps some where, i have a standyne pump on my truck right now and i want to get a rough estimate on how old it is and when it had beed replaced, there is a plate on the pump with info but i cant read it do to the postition it is in, i would hate to stick my head down in there with little mirriors and stuff with wasp buzzing around, and it turns out there is no date.
  #32
Old 05-27-2011, 02:30 PM
1BadB2's Avatar
1BadB2
1BadB2 is offline
I don't have Moose products. I am using DPS pump.
  #33
Old 05-27-2011, 02:33 PM
joe f350's Avatar
joe f350
joe f350 is offline
imho i say go with dps half the price and theres a company behind the product and made better power for half the price
  #34
Old 05-27-2011, 03:16 PM
David85's Avatar
David85
David85 is offline
My moose pump wasn't anywhere near $900. I think Joe might be confusing the original moose pump with a newer higher output that came out recently.
Not sure how the DPS works, but the moose pump is actually a rebuild of whatever pump you send in, so there is no fixed price. Mine was evidently a decent core so the cost wasn't much more than what a regular reman would have been but I prefer not to publish the exact amount.
It was more than $450 though.....
  #35
Old 05-27-2011, 03:25 PM
ManicMike's Avatar
ManicMike
ManicMike is offline
Originally Posted by 1BadB2
HP number is low because there was no RPM pickup. The horsepower curve is correct, but at the wrong point on the graph due to the machine not knowing the RPM.
A dyno does not need to know RPM to calculate torque as it is a real physical force. Horsepower, however is a made up number, a byproduct of torque calculated by torque @ a given RPM.
That graph is a pull from 1600rpm - 3200rpm approximately.
So.
(Torque X RPM) / 5252 = Horsepower
558 x 2200 / 5252 = 233rwhp
528 x 3200 / 5252 = 321rwhp (at the peak of my HP curve)
This is confusing me. Why mention the 233 number when overall the best is 321?
321whp and 558wtq sounds right for a diesel.
  #36
Old 05-29-2011, 04:24 AM
1BadB2's Avatar
1BadB2
1BadB2 is offline
I'm not sure why he posted the 233 and not the 321... maybe he just got excited and missed it?
If you guys are impressed with this... stay tuned. This was just my "tester". Now that I know I can make it up into the 400whp range fairly easy, and it has held together for the last 10,000 miles without a hint of trouble at 321/558... I'm going into a full build.
Everyone in the IDI world is in for a treat. I will be introducing bolt on parts that I will sell if there is enough interest, I will be unveiling never before seen DPS parts, as well as a full write up on how to build a reliable IDI capable of 400+whp without having to take out a loan to do so.
  #37
Old 05-29-2011, 07:46 AM
Otahyoni's Avatar
Otahyoni
Otahyoni is offline
Oh, there will be interest.... I sure am interested....
Seems like a very do-able and affordable build so far....
  #38
Old 05-29-2011, 12:10 PM
91dirtydiesel's Avatar
91dirtydiesel
91dirtydiesel is offline
Im excited to see! Keep up the good work man!
  #39
Old 05-29-2011, 12:36 PM
joe f350's Avatar
joe f350
joe f350 is offline
i planing to run a hx35 turbo on my truck with dps fuel system and head studs
  #40
Old 05-29-2011, 02:07 PM
ManicMike's Avatar
ManicMike
Dude, that IS exciting. I'd honestly be happy with a solid 250whp/450wtq turbo'd IDI. That'd be MORE then capable in my book.
  #41
Old 05-29-2011, 02:22 PM
snaponprofile's Avatar
snaponprofile
snaponprofile is offline
I wonder what mine will make on the dyno. Its gonna be intercooled and up 3 flats - but it still has just has BB's and normal IP? I guess we will see......
  #42
Old 05-29-2011, 02:27 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
most likely right in the respectable neighborhood of Sycostang67's engine; "186whp 363wtq @ 10psi."
(ATS waste gated w/BB codes.)
keep in mind it took moose goods to set the last record of just over 200 ponies,as well as (we don't know for sure) at least a boost gauge pegged @ 15 psi.
  #43
Old 05-29-2011, 02:29 PM
snaponprofile
Yeah, I was thinking that. He wasn't intercooled though. I wonder if it will be different?
  #44
Old 05-31-2011, 01:51 PM
94 smokin stroker's Avatar
94 smokin stroker
94 smokin stroker is offline
Did you guys even think that he didint have the type4 torque cam and could have turned more rpm if he wanted to without damage id say if he spun it around 4,000 he could get the high 3s or low 4s
  #45
Old 05-31-2011, 02:33 PM
Aune163rd's Avatar
Aune163rd
Aune163rd is offline
I wouldnt put it past this engine, the torque cam seems like something that might be worth investing in for pretty much any IDI that you want more power from. Even though your fuel mileage might go down.
Quick Reply: another IDI record breaker! 321 HP & 558 ft-lbs of torque! DPS Pump & Injectors
