Hedman #89210
Old May 25, 2011 | 09:42 PM
wa150's Avatar
wa150
Hedman #89210
I'm thinking of putting these on. Pros and cons anyone? I was going to go with fender exits but I do a bit of off roading and don't want them to get beat up with rocks. Supposedly these fit my '79 F-150 4x4 400 w/ manual tranny and shouldn't be a problem fitting around clutch linkage or give the starter a problem. Do you all agree?
Old May 25, 2011 | 09:56 PM
HIO Silver's Avatar
HIO Silver
Here's the info straight outta the Hedman catalog:
Years: 77.5-79 4WD 1/2 & 3/4 ton pickup, F-150, F-250, F-350 (Light Duty Only)
Engines: 351-400M
Headers:
Painted - PN 89210
HTC Coated - PN 89216
Elite or Stainless - PN 89218
Applications:
A/C - Yes
P/S - Yes
Transmissions:
Automatic Column Shift - Yes
Automatic Floor Shift - Yes
Standard Column Shift - No
Standard Floor Shift - Yes
Footnotes: 4, 6, 44, 166
4 = Includes parts necessary to retain emission devices (50-state)
6 = Modify stock exhaust to retain catalytic converter
44 = Will not fit Dana 60 front differential
166 = Will not fit multi-shock absorbers, factory or aftermarket installations.
Emissions: L
L= 1977-1979 only, 50-state legal for these years
Old May 25, 2011 | 10:10 PM
buckbr549's Avatar
buckbr549
I have the same truck with a NP 205 and the driver side pipe is hard to fit over the top of the cross member and miss the transfer case. The right side is about 3/8 inch from the starter. That's why i'm looking into fender exit headers. It looks like a cleaner setup.
Old May 26, 2011 | 12:49 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Chassis exit headers are like drugs, JUST SAY NO. I had a set of chassis exits on a 78
4x4 F150 351m auto.
And they we a major PITA, drive shaft hitting issues, real crazy routing of the exhaust system to get around the xmsn/xfer case crossmembers.
Basically caged the starter, NEVER AGAIN! I put fenderwell exits on my 79 F250 4x4
351M 4spd w/36's wheel the hell out it and have not really had any "rock" issues.
I would only tell you to keep asking opinions about them (chassis exit) before you purchase and install a headache.
Fenderwell exits are the only type I even will consider to use.
Old Jun 1, 2011 | 11:19 AM
wa150's Avatar
wa150
I have dual shocks up front with the coil. Do the fender exits have any problems fitting around these?
Old Jun 1, 2011 | 11:31 AM
77&79F250's Avatar
77&79F250
Ck the install notes on different brands, I remember something about a few brands NOT fitting the set up you have. I'm sure there is a brand out there that will fit.
Old Jul 24, 2011 | 09:28 PM
ford5o's Avatar
ford5o
look up hedmans 89360. im looking into them for 79 150 with dual front shocks and coils
Old Jul 24, 2011 | 10:45 PM
co425's Avatar
co425
Chasis exits can be an issue unless L&L makes a set for your application. Had issues with flow tech and headman before swaping a 460 and running L&L's. No issues what so ever with them.
Building_Fords
Oct 19, 2016 07:35 AM
old409
Jun 10, 2015 09:01 AM
sperober1
1997 - 2003 F150
Jul 1, 2014 06:47 PM
DaBigMan
Jun 20, 2009 03:01 PM
bremen242
1997 - 2003 F150
Apr 13, 2009 08:09 PM
