voltage issue?
Old Jul 24, 2011 | 07:54 PM
impalaslayer's Avatar
impalaslayer
voltage issue?
well i got this stupid truck almost done and now this pops up. basically the lights pulse and some time just dim, its totally random. any ideas?
‪79 f250 lighting issue‬‏ - YouTube
Old Jul 24, 2011 | 08:00 PM
kingford72's Avatar
kingford72
you may have a short in the light system somewhere. Does you light switch click when it does it. Mine did the same thing when it is doing it I disconnected the four wire plug for the rear, front right, and front left, when it stopped I new it was in the front right corner, sure enough the wire rubbed through on the alum grill shell where it attaches to the headlight bucket.
Old Jul 24, 2011 | 10:03 PM
fmc400's Avatar
fmc400
MSEE
kingford72 is correct; you have a short downstream of the headlight switch. The circuit breaker inside the headlight switch is interrupting, causing the lights to blink.
Old Jul 24, 2011 | 10:50 PM
co425's Avatar
co425
Might not even be a short. Over time the breaker in the headlight switch will do that no mater what. The proper thing to do is convert to a relay set up for you headlights. Swapping the switch wouldnt hurt either.
JRT812
Dec 15, 2018 04:54 PM
KB88
Aug 3, 2015 05:28 PM
rottenstock
15
Sep 16, 2013 07:32 PM
sd59f100
Jan 29, 2009 01:46 AM
