1999 4x4. trouble
Old May 25, 2011 | 06:10 PM
blackwaterairsoft's Avatar
blackwaterairsoft
1999 4x4. trouble
just wondering what would make my tires feel like they are chopping when i turn into a paved parking lot space it feels like the weels are chatering..chaffing scuffing ect..it is in all 4 wheel drive when this happens.. and then when i put it in 4 wheel high and turn on the durt it feels like the front end is going to fall apart,, but when i put it in 4 wheel low on the dirt it is ok.just wondering i dont know much about 4 wheel drive.
Old May 25, 2011 | 08:54 PM
alwaysfords41's Avatar
alwaysfords41
Could be clutch packs in the limited slip rear end binding.
Old May 25, 2011 | 09:11 PM
alloro's Avatar
alloro
Originally Posted by blackwaterairsoft
when i turn into a paved parking lot space it feels like the wheels are chatering..chaffing scuffing ect..it is in all 4 wheel drive when this happens.
Never drive in 4WD on dry pavement. Your owners manual specifically tells you that damage to the 4WD system can occur if you use it on dry pavement.
Old May 25, 2011 | 09:24 PM
alwaysfords41
It's a 99 so I think what he is calling "all 4WD" is auto 4WD, he doesn't have a 2WD position on the dial.
Old May 25, 2011 | 09:32 PM
alloro's Avatar
alloro
Then he should say a4wd and not 4wd, because there is a completely different diagnostic for each.
Old Jun 26, 2011 | 01:05 AM
steveaus's Avatar
steveaus
I'm having the same issue with A4WD. Anyone know what the problem is (or where I should ask the mechanic to look)?
Old Jun 26, 2011 | 10:10 AM
alloro's Avatar
alloro
The very first rule of A4WD is that all 4 tires have to be the same size (diameter). If the fronts are worn more than the rears, or vise-versa, you end up with the two axles rotating differently enough to fool the A4WD system into thinking the rear wheels are slipping. In turn, the result is power gets sent to the front and the two axles start fighting each other. Often you can confirm if this is the cause by swapping the front and rear tires on ONE SIDE ONLY. It can be either side, as long as both tires getting swapped are from the same side.
Old Jun 27, 2011 | 04:29 PM
kprussel's Avatar
kprussel
Well... my old 98 4X4 EB Expedition had 2wd, auto 4wd, 4wh, 4wl, so I would guess the 99 4x4 would have this also. But it does sound like he is driving 4wd on dry pavement which will cause this to occur.
Old Jun 28, 2011 | 01:52 PM
TenHoles's Avatar
TenHoles
99 did not have a 2wd position. Its A4WD 4HI 4LO only.
It sounds to me like what someone already posted. I'd suspect the clutches are binding in the rear diff.
Change the fluid making sure to have the correct amount of friction modifier added when filling with new fluid.
gretchen5150
Nov 25, 2014 10:51 AM
murph1
2009 - 2014 F150
Mar 15, 2011 08:18 PM
UglySinceBirth
15
Feb 15, 2010 12:01 PM
carysf250
Aug 4, 2009 01:51 PM
LtRdNate
1983 - 2012 Ranger & B-Series
Apr 30, 2004 02:43 PM
