Modular V10 (6.8l)
Wont Start
Old May 25, 2011 | 05:44 PM
Chakeeche's Avatar
Chakeeche
Wont Start
My 99 F250 6.8 truck wont start. Fuses good, new fuel pump, grounds good, fuel pressure 35psi, NO spark. changed the cam sensor, no codes. Any ideas ??
Old May 25, 2011 | 08:40 PM
Fordfanatic4life's Avatar
Fordfanatic4life
trip the fuel pump safety switch by chance ???
Old May 26, 2011 | 06:46 AM
projectSHO89's Avatar
projectSHO89
He wouldn't have 35 psi at the rails if it were tripped.
NO spark.
How did you test for this? Cam sensor cannot cause a "no spark" condition although the crank sensor can.
Verify that the CEL illuminates properly during bulb prove-out.
Verify fuse F30 circuit as it supplies power to all the individual coils. Should be HOT in both RUN & START.
Old May 26, 2011 | 07:25 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Two things, first with the key on, check the RED wire at the injectors for +12 volts. This will tell you if the PCM (generally) has voltage, and the COPs too, of course.
Second, the crank sensor is under the AC compressor. I'd hook a digital volt meter set to AC volts, connect to the sensor and crank the engine over and see if you get any voltage out of it.
Old May 26, 2011 | 08:38 AM
Chakeeche's Avatar
Chakeeche
Won't Start
THANKS GUYS............I will do a few more tests and let you know. I will get after the crank sensor today if if quits raining.
Old May 30, 2011 | 05:37 AM
Chakeeche's Avatar
Chakeeche
Guys WE got it...................!!!! After loosening the motor mounts lifting the motor slightly so the A/C compressor could be loosened and moved out of the way I changed the crank sensor. Reassembled and it runs. The only thing now is the NEW fuel pump sending unit from NAPA only reads 3/4 when the tank is full. I guess as long as it reads E when empty that what matters.
Started off with the wires chewed off the fuel pump. droped the tank 2x siphoning fuel x2 new fuel pump, checking every wire x10 checking inertia switch, cam sensor, purchase of a fuel pressure guage , it was the #@!?** crank sensor. The good part is it runs.
THANKS !!!
SDBugler
6.4L Power Stroke Diesel
Sep 12, 2019 11:03 PM
bobbyt89
Dec 2, 2012 09:16 PM
mx495
Sep 17, 2007 05:24 PM
jasonmoss
1983 - 2012 Ranger & B-Series
Dec 21, 2004 08:13 PM
nate6969
Aug 28, 2003 08:11 PM
