1978 - 1996 Big Bronco
Alternator bearing
Old May 25, 2011 | 04:59 PM
Encho's Avatar
Encho
The Southernmost Mod
Alternator bearing
Hey guys, check this out:
https://www.ford-trucks.com/forums/1...l#post10385665
Old May 25, 2011 | 08:44 PM
mikeismadness's Avatar
mikeismadness
thats prety crazy. although i prob just would have taken the 3 bolts off the alternator and spent the money and got a new one, but mines weak as it is haha
Old May 26, 2011 | 06:21 PM
F150xlt's Avatar
F150xlt
I believe these are the two bearing part numbers.
6000-2rs
6303-2rs
Pictures of the bearings at the links below.
10 Bearings 6000-2RS 10x26x8 Sealed:Ball Bearings
6303-2RS Bearing 17x47x14 Sealed:Ball Bearings
Old May 26, 2011 | 08:17 PM
Encho's Avatar
Encho
Thx F150, that should make things easier for me... now which one should be the one in the back?, i'm thinking 6000 but i'm not sure, and i won't be doing them both, since the front one has been replaced already.
Old May 26, 2011 | 09:19 PM
F150xlt's Avatar
F150xlt
The smaller bearing is for the rear. Looks like you also lost the rear bearing cover plate.
Take a ruler and get a rough measurement of your rear bearing and compare the size to the 6000-2rs.
The sparks you saw may be the rotor scrapping against the stator because of the
bad bearing.
Old May 27, 2011 | 01:56 PM
Encho's Avatar
Encho
Oh no, i didn't lose the cap, it was the cap flying out which finally showed me what the issue was. I went to one of the bearing stores today, didn't have the sample with me, but the guy gave me an estimate of around $6.5 for the bearing, so this should be a very inexpensive fix.
Old Jun 1, 2011 | 08:46 AM
Encho's Avatar
Encho
Hey guys, here is the deal: since the bearing "exploded", all that's left in the axis is the internal race, i can't place any pulling device behind it to pull it out, so i would like to hear what ideas you have, or if anyone was in the same situation, which procedure was followed to remove it.
Old Jun 1, 2011 | 09:56 AM
F150xlt's Avatar
F150xlt
So the inner bearing race is seized on the rotor shaft?
A shop would use a bearing separator plate and a press.
You could use a bench grinder. Grind it down in a couple of spots to weaken
it and the race should eventually break loose.
Norsegod127
1983 - 2012 Ranger & B-Series
Feb 20, 2015 10:23 PM
tbear853
Jan 8, 2013 10:08 PM
Encho
Jun 2, 2011 09:43 AM
Americanmadeford
May 15, 2008 05:54 PM
NorthPac
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 13, 2006 09:09 PM
