need help 2003 f350
Old May 25, 2011 | 12:22 PM
schilldon's Avatar
schilldon
need help 2003 f350
driving down road pulling trailer, truck chugged and stalled. Acted like ran out of fuel. Tried to restart whouldn't start. Left sit for 10 min started and ran fine. Ran a couple miles same thing. Got truck back home stalled out lots on way. Unhooked from trailer pulled into shop checked fuel filters whitch have been changed 100 miles ago. Pulled fuel pump and replaced with new one. Hooked up to trailer drove down road same thing happend. Truck seems to run fine without load. did hook up to coad reader and found no codes.
Thx for any help.
Old May 25, 2011 | 02:16 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Is the truck stock, or do you have a tuner on it ?
Old May 25, 2011 | 02:57 PM
schilldon's Avatar
schilldon
stock have any ideas
Old May 25, 2011 | 08:16 PM
BLADE35's Avatar
BLADE35
any smoke???
last oil change??
check fuel press
need to monitor your ICP and IPR
Old May 26, 2011 | 11:55 AM
IB Tim's Avatar
IB Tim
Hoe does he do that?
Old May 26, 2011 | 02:32 PM
schilldon's Avatar
schilldon
a little smoke on start up
took it for drive today put 120 miles on it ran fine
just when hooked up to trailer it quits
changed oil about 2000 miles ago
fuel filters less then that
Old May 26, 2011 | 02:33 PM
texans's Avatar
texans
With an autoenginuity.
Old May 26, 2011 | 08:02 PM
BLADE35's Avatar
BLADE35
I wish I had the AE one day
I use scangauge II
www.scangauge.com
click here^^^^
it does quite abite best deal for the money
ICP,IPR,FICM,BOOST,VGT,and a ton more
it does not do fuel pressure,but most everything eles
Its best to get some kinda gauges they will pay for themself in the long run,just by knowing good from bad parts
Its a good feeling knowing where your truck stands
what kinda fuel filters did you use
Old May 29, 2011 | 10:49 PM
schilldon's Avatar
schilldon
checked fuel 55 psi at start
when driving down road 55 psi when u punch it drops to 48 then climbs back up
is this normal
Old May 29, 2011 | 11:01 PM
BLADE35's Avatar
BLADE35
is this normal
what kinda fuel filter some off brands lose 10psi
Its getting close to injector damage at 48 I would put in the blue fuel pressure spring
and it may even drop more pulling a trailer
IIRC 45psi is the minumum
Old Jun 2, 2011 | 07:30 PM
schilldon's Avatar
schilldon
could this be a problem with oil cooler?
Old Jun 2, 2011 | 08:57 PM
BLADE35's Avatar
BLADE35
It could be this is out of the tech folder
when the pcm sees ECTs at 221f it will defuel
when the pcm sees EOTs at 253f it will defuel
check it out
https://www.ford-trucks.com/forums/9...-pressure.html
click here^^^^^^^^^^^^^^^^^^^^
what temps are you seeing
whats your ECTvsEOT spread
without any gauges its hard to say
Kb528
May 8, 2014 09:14 PM
Fla.Cracker96
Feb 7, 2014 07:44 PM
spinge
30
Nov 10, 2011 09:40 AM
ford2002f150
1997 - 2003 F150
Mar 13, 2011 12:04 AM
