No start condition
Old May 24, 2011 | 09:41 PM
JRS2's Avatar
JRS2
No start condition
Ok, have a 5 spd manual and a 5.0 - just replaced the trans and transfer case. I only have about half the clutch pedal - wouldn't bleed down all the way. When I turn key, fuel pump whirrs, but I get nothing at the starter. It's been sitting maybe about 2 yrs, but ran good back then. The electrical connectors there for the clutch master cylinder, 1 - 2 wire connector for the trans and same for the transfer case. Am I forgetting something ? I noticed that light for the transfer case seems to stay lit in 4 wheel low, even though I shift into different postions. Thoughts ?
Old May 25, 2011 | 10:45 AM
Lazy K's Avatar
Lazy K
My first thoughts would be a bad neutral safety switch. Use a wrench or similar to jump the two big terminals on the fender mounted starter relay and see if the starter then runs.
Old May 25, 2011 | 07:30 PM
JRS2's Avatar
JRS2
LazyK:
Ok, where is the neutral safety switch located - on a 5 speed ? I'll try the solenoid jumping as well ...
Old May 26, 2011 | 06:58 AM
Lazy K's Avatar
Lazy K
If you look under the dash at the clutch pedal linkage the NSS should be on the pushrod from the clutch pedal going to the masyer cyl.
Old May 26, 2011 | 07:29 PM
JRS2's Avatar
JRS2
Ok, I did attach that one, there are about 16 wires give or take attached - correct ? I'll check again and make sure I can't install it 180 degrees off .... Haven't tried to jump the solenoid yet, but will this weekend. My glovebox door doesn't shut tight and the light must have drained down the battery ....
Old May 27, 2011 | 09:38 AM
Lazy K's Avatar
Lazy K
No, there are only 4 wires, I think you are thinking of the ign. switch. Look right at the firewall on the pedal linkage.
Old May 28, 2011 | 09:40 PM
JRS2's Avatar
JRS2
LazyK:
Here's an update. I did jump the solenoid and it started. Replaced solenoid - thinking it was bad, but I suspect now the neutral switch may be blocking the starting. I did find a 2 wire connector which plugs into a switch on the drivers side - top plate which holds the shift rods. Will look for that other switch.
Old May 28, 2011 | 09:46 PM
JRS2's Avatar
JRS2
One more thought, you indicated the NSS being on the clutch clutch rod going to clutch master cylinder. Yes, there are many wires rather than 4 going to that connector. Seems like if it's bad, would need a new master cylinder ? Starting to think I may have a wiring issue though. My transfer case indicator lamp is not working correctly either. May need a wiring diagram to check normalcy of readings ....
Old May 29, 2011 | 04:10 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/1...ck-switch.html Click on this link and read through the thread. Some good pics and info on the NSS which will help you.
Old May 30, 2011 | 11:03 AM
JRS2's Avatar
JRS2
Thanks Lazy K, will jump back into it ....
Old Jun 2, 2011 | 08:51 AM
JRS2's Avatar
JRS2
LazyK:
You were correct, jumping those 2 pins worked to make it start normally. Now I just need to free up a brake drum and try to drive down a rough road and hopefully loosen those air bubbles in the master/slave cylinder so my pedal firms up.
Thanks for the help ....
hasseled
Bronco II
Aug 15, 2012 01:15 PM
CoachRobb
Sep 7, 2011 08:55 PM
ckutter
Aerostar
Jan 9, 2006 11:11 PM
SoArkSI
Nov 5, 2005 08:43 PM
fatherdoug
Aerostar
Sep 23, 2005 07:44 PM
