Truck Problems
Old May 24, 2011 | 07:27 PM
Drake430's Avatar
Drake430
Truck Problems
SO, my truck decided to start slowly killing itself about a day ago.
I got the error code P0404. I've now got excessive amounts of white smoke if I touch the gas pedal. If I try to give it a lot of gas while its sitting there, then it will cutout some and blow even more ridiculous amounts of white smoke. I also couldn't hear the turbo even begin to spool up. I just tried disconnecting the EGR valve to see if it would do anything, and I still had all of the same things happening.
Anyone have any ideas?
Old May 24, 2011 | 08:09 PM
bismic's Avatar
bismic
Try to determine if the white smoke smells like coolant or diesel.
Drive it, park on a "decline", and pull the EGR valve to see if there is moisture under it.
2006powerstroke90's Avatar
2006powerstroke90
I believe that code is egr related.
Do you still have the stock egr system? Any coolant smell? Coolant loss? Or coming out of the exhaust?
Do you know your oil or coolant temp?
I think your egr cooler failed.
Old May 26, 2011 | 07:28 PM
Drake430's Avatar
Drake430
Problem solved, I took out the EGR valve, and it was basically a block of carbon, so I cleaned it out and the truck immediately ran better! Thank goodness that did it
Old May 26, 2011 | 07:39 PM
cheezit's Avatar
cheezit
if the concern happens again you may need to remove and clean the intake and replace the egr cooler
rofl_copter3
Jun 15, 2014 06:38 PM
got2befast
Apr 25, 2011 07:33 PM
onehandedbandit
Mar 31, 2011 09:48 AM
weldingfreak
Feb 12, 2006 03:10 PM
King of the Road 04
Aug 9, 2004 12:29 PM
