Sponsored by: Kumho
1996 Power Steering operation?
Old May 24, 2011 | 02:22 PM
lasitter's Avatar
lasitter
I'm guessing that the power steering pump doesn't "know" where it's sending the hydraulic fluid and the gearbox has no idea where it's coming from. So I was wondering if there was a manual or diagram on the internet somewhere that would show me how things change when you turn the steering wheel and thereby "call" for more power assist. I'd also like to know what route the (continuously produced?) hydraulic fluid takes when the steering wheel is "straight ahead" and almost no assist is needed. Is there a shunt or cutoff that reduces engine load when assist is not needed? Many thanks.
Old May 24, 2011 | 06:19 PM
Ford_Six's Avatar
Ford_Six
There is a spool valve in the upper part of the steering gearbox that directs fluid based on need. When there is no need for power, it is open and the fluid just circulates.
Old May 24, 2011 | 07:30 PM
lasitter's Avatar
lasitter
With the 2011 trucks switching to electric assist power steering, how does this change things? I'd love to see an internal diagram that shows how the flow of the fluid is routed. The new set-up must have some way of determining when the spool valve opens so the electric pump kicks up in output.
Old May 25, 2011 | 12:00 AM
Ford_Six's Avatar
Ford_Six
Well, I haven't had a chance to deal with Ford's system, but I have dealt with other electro-hydraulic power steering systems. Usually they operate one of two ways: Constantly like a standard hydraulic system, or intermittently on demand. The only change for the constant ones is the power source for the pump, although some did use a different fluid that in some cases is extremely hard to find now.
There are a few different types of intermittent systems, but most employ some sort of sensor to determine how fast and how far the steering wheel is being turned, then cycling the pump to provide assist through a fairly standard valving setup. These systems usually cut out or at least significantly reduce output at higher speeds.
bluemtn95ford
Sep 22, 2013 12:26 PM
redtantrix
16
May 13, 2010 03:08 PM
muscletruck7379
Nov 18, 2004 04:54 PM
WolfmanSpike
Jun 13, 2004 05:18 PM
MatthewB
Oct 25, 2001 06:04 PM
