Sponsored by: Kumho
hydraulic assist steering
Old May 5, 2003 | 08:35 PM
redtantrix's Avatar
redtantrix
Lightbulb hydraulic assist steering
Does any one know how to make a hydraulic assist system ?
I know i need a hydraulic ram and lines but how to tap into the steering box?
I want to make my own setup and not Pay for the expensive aftermarket units.
Thanks
Old May 5, 2003 | 08:36 PM
pfogle's Avatar
pfogle
you could try the junk yards a lot of the time you can get a whole setup for not a whole lot.
Old May 6, 2003 | 07:08 AM
SplashMan's Avatar
SplashMan
Check out this guy , he is a great fabricator and installed hydro assist on both his Bronco and his Zuki.
Old May 6, 2003 | 02:29 PM
72f100's Avatar
72f100
If your a decent fabricator and a good bargain shopper you can put a system together for ALOT less that AGR rips you off for. There's a place in Texas that'll clean and port and tap your steering box for hydraulic lines for $150. They sell rams for $150 as well but you can get them cheaper if you look around. I went to an industrial supply place here in town and bought a brand new 1 1/2" double acting ram for $100. Hydraulic lines can be found pretty readily at farm supply stores for pretty cheap.
What you'll want as far as a ram is concerned is, if you'r using your stock power steering pump, a 1 1/2" bore 8" stroke double acting cylinder. You will want to measure the total travel at the tire rod from full left turn to full right turn to deturmine the proper stroke. Mine, as well as most Fords was 8". Also, if you have a more powerful power steering pump you can go w/ a larger ram bore. Keep in mind that if the bore is too large the ram will react too slowly and cause problems w/ the steering.
Here's a site for you to check out:
www.westtexasoffroad.com
Old Feb 20, 2010 | 09:53 PM
oreocreaming's Avatar
oreocreaming
BUMP!!!!!! This is my next project
Old Feb 21, 2010 | 11:07 AM
oreocreaming
anyone in california that wants to make some cash rebuilding my steering box and drill and tap it for the fittings for this system?
Old Apr 14, 2010 | 11:24 PM
oreocreaming
just got it back last weekend. cost me a bit but well worth it. turns my 42's like they are 32's. nice, smooth movement, no need for a steering stabliser anymore.
Old May 12, 2010 | 04:46 PM
seanyounk's Avatar
seanyounk
Who drilled your box?
oreocreaming;
Who did you use to drill out your steering gear box?
Old May 12, 2010 | 05:16 PM
oreocreaming
Lee Manufacturing Company Sun valley, CA 91352 Steering gears Pumps Reservoirs
there is his link. he quoted me 900 out the door, charged me 1753 but only made me pay 1500. well worth the 1500. good guy, loves to talk. hes a old school racer.
Old May 12, 2010 | 07:28 PM
seanyounk's Avatar
seanyounk
Wow!!!
That is way more than I was hoping.
I ordered a new gear box from redheadsteeringgear.com in WA for 285 shipped. I am going to drill the box out myself and buy a reman pump for 65 and turn up the flow a little bit from the instructions on West Texas off road. I bought a ram from industrial supply for about 90. I am hoping to be into the whole thing for about 600 with new Moog tie rod ends. Am I missing something?
Old May 12, 2010 | 09:39 PM
oreocreaming
he can do just your box. I had him do everything start to finish. Including rebuilding my pump and a tota overhaul on my gear box
Old May 12, 2010 | 09:42 PM
oreocreaming
nope, you got it. Make sure the ram is matched diamiter and stroke to your pump and box. Too long and you'll brake something, to big or small and it will either over or under push your tie rod and brake something
Old May 13, 2010 | 11:56 AM
seanyounk's Avatar
seanyounk
I bought the ram a while ago when I was researching all of this. I am pretty sure it has an 8" throw, but I would have to look it up again.
Thanks for the advice.
Old May 13, 2010 | 12:05 PM
seanyounk's Avatar
seanyounk
redtantrix;
Some of these links may be useful for you;
Affordable place to drill your steering gear box if you are afraid to do it;
hydrosteering
Instructions on getting a little more fluid pressure from your power steering pump;
http://westtexasoffroad.homestead.co...rsteering.html
Where I bought my ram;
https://www.surpluscenter.com/home.asp
Instructions on how to drill your steering gear box;
RamchargerCentral.Com - RamchargerCentral.Com - How Tos - How To Add Hydraulic Ram Assisted Steering To Your Dodge Truck - gmule
Where I bought my steering gear box;
Red-Head Steering Gears, Seattle WA - Red-Head Steering Gears Home
Old May 13, 2010 | 12:06 PM
seanyounk's Avatar
seanyounk
I just noticed the date of the original post!!!
I am an idiot...hopefully he has figured it out by now.
