Remote mounted module?
Old May 24, 2011 | 10:16 AM
ChristopherN's Avatar
ChristopherN
Hello, I'm looking to replace my ignition coil and Rock Auto gives me 4 different motorcraft coils for Standard and Automatic transmissions. For the Automatic it has: Automatic trans.; w/ Remote Mounted Module; F2TE-12127-AA
Automatic trans.; w/ Distributor Mounted Module; F2TE-12127-AA
Which one do I get? Does my VIN number give me a code to look up to say which is which?
I tried the search function but nothing came up on this particular subject.
Old May 24, 2011 | 10:25 AM
subford's Avatar
subford
Are you wanting to replace the Ignition Coil or the Ignition Module?
I do not understand what you are saying.
Old May 24, 2011 | 10:46 AM
ChristopherN
That, but in motorcraft form.
Old May 24, 2011 | 10:52 AM
White Max's Avatar
White Max
That list on RockAuto is showing that it fits all of those configurations. If you want the Motorcraft one, the P/N is DG470.
Old May 24, 2011 | 10:55 AM
subford's Avatar
subford
That should be a Ford #F2TE-12127-BA.
It does not make any difference if it is auto or standard or where the Ignition Module is mounted, it takes the same coil.
Old May 24, 2011 | 03:55 PM
Edgethis's Avatar
Edgethis
I just installed that same MSD coil you pictured. Its nice and was only a dollar or two more then the standard coil that Advance Auto had.
Old May 26, 2011 | 06:50 AM
TexasGuy001's Avatar
TexasGuy001
I had the MSD one and went back to Motorcraft.
Old May 26, 2011 | 08:28 AM
jfmaz's Avatar
jfmaz
Why? Problems with the MSD?
Gembone
Dec 11, 2014 12:28 PM
fitzwell
Sep 20, 2012 10:13 AM
Craigwell
Dec 6, 2009 09:15 AM
admiral1960
Sep 7, 2007 12:43 PM
cyborg69
Electrical Systems/Wiring
Jan 24, 2004 03:54 PM
