Sponsored by: Real Truck
cab lights mod
Old May 24, 2011 | 10:03 AM
SpeedRebel09's Avatar
SpeedRebel09
cab lights mod
My truck is a 1999 f250 superduty xlt supercab if I were to buy everything from ford would there be a plug to just plug the harness into? If so where at? My truck does not have overhead console.
Also where could I find a template?
Old May 24, 2011 | 10:18 AM
Monster-4's Avatar
Monster-4
Here is an install link.
Motoman's Madness
Depending if you have and over head console or not you'll need one or the other harness. But other than that there should be a plug available either way.
Old May 24, 2011 | 10:57 AM
SpeedRebel09
Cool so with my truck not having the overhead it should be located under the passenger side kick panel?
Old May 24, 2011 | 11:29 AM
Rongold's Avatar
Rongold
Clearance Lamp Install
Don't use Motoman's measurements, as they are not correct. If you read his post, you will see him trimming the lamps so they fit flat on the roof. Use the measurements in this post.
https://www.ford-trucks.com/forums/7...installed.html
That is my post--My lamps fit perfectly. Check out the pictures below.
Just make sure that all 5 lamps face perfectly straight ahead. Don't angle the end ones outward--They go facing dead straight forward. The end ones are slightly rearward of the 3 center ones due to the curvature of the windshield, but they still face straight forward.
RON
bird-n-buck
Nov 27, 2012 09:57 PM
scottstevo
Feb 10, 2012 08:07 PM
2006powerstroke90
Jan 18, 2011 09:13 PM
batesfarmer
Feb 4, 2006 07:36 PM
66jj
Electrical Systems/Wiring
Dec 25, 2004 11:11 PM
