No start no glow plug buzz
Jan 17, 2011 | 07:24 AM
Went to start my truck this morning plugged in, turned the key and there was no glow plug buzz like usual.
It cranked and cranked and no start...
Where should I start looking?
Glow plug relays?
Jan 17, 2011 | 07:30 AM
Test battery voltage, verify batt / alt / cables.
Then... fuel gelling? What is your temp?
Fuel pressure?
Then... FICM voltage test.
Jan 17, 2011 | 07:36 AM
It's about 15 deg.
I checked the ficm a little while ago and it checked out fine.
Truck was cranking over fine. Nice and fast like usual. I got oil pressure on my gauge.
No codes.
Jan 17, 2011 | 07:39 AM
Fuel pressure?
Bet you have a tank of gel.
Jan 17, 2011 | 07:43 AM
I hope not. I'm unsure of the fuel pressure. I can check the secondary fuel filter? That should be full or just geled up?
Also why can't I hear that buzz?
Jan 17, 2011 | 08:07 AM
Jan 17, 2011 | 08:11 AM
I will go home at lunch and throw a heater under the fuel tank and throw some diesel kleen in there. see what happens tonight. I really hope its something minor.
but that diesel untreated didnt look to good.
I just filled up sat morning, didnt start the truck or atleast try to until this morning.
turns out, truck was never plugged in, it came unpluggecd from inside the garage.
Jan 17, 2011 | 08:14 AM
Charge the batteries while you are at it.
Technically, if it is a wax dropout and not just gelling, you need to heat the whole fuel system above 50F to get the wax to reabsorb.
If you have contractor grade propane heaters, I would heat the whole garage.
You need Diesel 911 and cetane boost, not Dieselkleen.
Jan 17, 2011 | 08:27 AM
Thanks for your help
I will charge the batteries too.
Trucks in the drive way. It won't fit in the garage.
I have a couple of good heaters I will throw under it.
I will go and grab some of that stuff and throw it in.
I really hope this fixes the problem. I just find it hard to believe that everything geled up in less than a day.
Jan 17, 2011 | 08:32 AM
You are between a rock and a hard place..
IT is a PITA to open filters and see if there is gelling..
Can you throw some blankets around the side of the vehicle to hold the heat in?
Be careful not to start a fire.
Jan 17, 2011 | 08:43 AM
Quote:
Originally Posted by
2006powerstroke90
Assuming you mean injector buzz..
Quote:
Honest question here...just trying to learn.
How can fuel gelling be related to this problem?
FYI...That buzz that you hear is not glow plugs. It's a combo of fuel pump, injector buzz (I think that depends on the flash), and vaccume pump. I think you may be headed in the right direction. What did you use to pull the codes with? When you get that tunner you are talking about getting, you might want to get a fuel pressure gauge as well. I would install it before the tunner my self for two reason.
1. It would really help you in a situation like this.
2. A big tune can really bring down fuel pressure under hard runs. Anything under 45 psi is consider really bad on your injectors.
Another thing you might want to consider (if you don't already) getting is an AE with the ford enhancements. That's if you plan to do your own wrenching. That thing is flat out amazing.
Jan 17, 2011 | 09:07 AM
Jan 17, 2011 | 09:13 AM
SteveBricks
I was thinking the same thing...any ideas?
Jan 17, 2011 | 09:16 AM
We are dealing with a no start condition in extreme cold.
SteveBricks
Steve!
See post below:
2006powerstroke90
It's about 15 deg.
No codes.
15F, way cold!
Please note, I am talking about 3 different things:
a) fuel gelling
That is it not flowing
b) wax dropout
where the fuel separates into its components
c) water freezing --- and separating from fuel as ice.
OP has no trouble cranking, has oil pressure (rule out LPOP), but no ignition!
FICM voltage good.
That leaves fuel pressure (test not run).
Fuel starvation will do that.
If biodiesel is used, another complication --- because it gels / wax drop out a lot more.
