Power Steering Conversion
Old May 24, 2011 | 08:38 AM
Sleeve's Avatar
Sleeve
Hi all,
I have a 73 F250 Highboy 4x4 with a manual steering gear. It seems that some time back I read on this site where this could be converted to the later model 78-79 power steering.
Has anyone here done this or know enough about it to walk me through this conversion? I found an F150 at the local wreckers that has all the parts still on it if it would work for a 3/4 ton.
Will I need to do some welding and fabricating to the frame to adapt the latter box?
I've had this truck for 18 years now but as I get older I think that reliable power steering for it would be nice for the next 18 years!
TIA for any and all help with this.
Old May 24, 2011 | 08:52 AM
daningraham's Avatar
daningraham
There is a lot of information on this site about how to do this coversion. Just do a search and you will find all that you need. I did this on my 74' earlier this year and used the box from a 78' F250 and had to have new hydraulic lines made. Yes you will need to notch the frame rail and the crossmember to make it fit. A plasma cutter and welder (and some patience) are all that you need.
Old May 24, 2011 | 08:57 PM
Sleeve's Avatar
Sleeve
Thanks I'll see what I can turn up with the search engine.
Old May 24, 2011 | 10:34 PM
grinnergetter's Avatar
grinnergetter
One thing I found while searching this subject is that I wish I would have had the drag link to mount up during mock up so the right amount of material was removed from CM. Just would have made life simpler.
Old Jun 26, 2011 | 05:16 PM
PA74F250's Avatar
PA74F250
Would anyone care to share how much of the cross member they removed? I'm thinking about 1.5" towards the firewall.
Kansas Ford
Oct 14, 2014 03:32 AM
1970f100guy
Feb 21, 2014 05:27 PM
Ripcity
Aug 30, 2013 10:44 AM
77F150Jason
Oct 15, 2010 08:36 AM
Goodold71
Oct 11, 2004 05:15 PM
